Old 13-05-2005, 08:48 AM   #1 (permalink)
Default help to speed up my pc
i have a amd 2600 +256 mb ram +80 gb pc
but it is so slow how i speed up it....
prem is offline
Old 13-05-2005, 10:19 AM   #2 (permalink)
Distinguished Member
anandk's Avatar
i assume u r using windows/xp.
reduce your start-ups. use win patrol to keep a watch on them.
use tune-up utilities or ace utilities. they clean up your junk files, registry, and also compact your registry. defragment your disk.
trust u use a good anti-virus and anti-spy. avast, avg & ms anti-spy, adaware are good ones in their respective categories.
disable windows services you dont need. here too win patrol; makes your job easy. this will free up resources.
for guidance visit : http://mywebpages.comcast.net/SupportCD/OptimizeXP.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 13-05-2005, 06:37 PM   #3 (permalink)
QA Juggler
saROMan's Avatar
try searching...there are loads of threads already
http://www.thinkdigit.com/forum/search.php
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 14-05-2005, 08:44 AM   #4 (permalink)
q3_abhi's Avatar
Read the digit issue(i dont remember the month)
There are some tips n tricks to speed up ur PC.
q3_abhi is offline
