Old 13-05-2005, 08:44 AM   #1 (permalink)
Default what is best configuration
hai
i want to buy a new pc my budjet is 20000 rs .please sugest me a good config... to buy
prem is offline
Old 13-05-2005, 07:43 PM   #2 (permalink)
budget is low,what is your requirement etc
how is this:
amd 2800 64 + asus 18n-e for abt 10.5
512mb ddr 400 hynix for abt 2200
80gb sata seagate for abt 3k
c
akshayt is offline
Old 14-05-2005, 01:22 AM   #3 (permalink)
The Hardware Labs
mohit's Avatar
@ akshayt
there is no amd 2800+ based on the socket 939 so the asus a8n-e mobo cant be used.
check here,
http://www.amd.com/us-en/Processors/...E10248,00.html
the hynix ram may not be available that cheap , min i think is for 2500-2700/-
@prem
what is the purpose of your new pc ?
budget is very very less for gaming though you can build a decent celeron based system.go for a ram which offers warranty like zion or something.also if u dont intend to use it for gaming then 256 mb of ram is sufficient.
for value gaming go for a amd 64 (754 pin ) 3000+ or 2800+ (if available , now d/c) with an asus k8n-e deluxe mobo. take a 80 gb sata hdd.
alternatively you can try
celeron 2.4 + intel orig 865 + 256 mb ram + 80 gb sata + liteon cd-rw + ibox cabinet + logitech value combo + 15" crt (lg/samsung/acer) etc
it will cost around 20 k then.
mohit is offline
Old 14-05-2005, 09:10 AM   #4 (permalink)
dude why would he go for a Celeron based alternative where in you can get the Sempron ones for a lesser price and more performance ?
take the config akshay suggested and replace the amd 2800 64 + asus 18n-e for abt 10.5 with Sempron 2600+ and the A7N8x mobo mate. The rest would still fit in easily in his budget.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 14-05-2005, 10:51 AM   #5 (permalink)
go for pentium 2.4A with a 865 chioset mobo costing 9.5K
Happy Computing :lol:
krishnathelord is offline
Old 14-05-2005, 04:36 PM   #6 (permalink)
The Hardware Labs
mohit's Avatar
@icecoolz
point noted dude ... ya he should go for a sempron based system ...
@prem
hey buddy go for the following
amd sempron processor 2800+ (socket a)
asus a7n8x-vm-400 motherboard (choosing this as it has excellent integrated grafix)
seagate 80 gb (non sata , as mobo does not support sata)
256 mb 400 mhz ram (zion/kingston/transcend)
15" crt (lg/samsung)
logitech value combo (optical mouse+ mmkb)
any decent cabinet like ibox with 300w smps
liteon cd-rw
thats it i think , it will be a very very good value for money config and will allow you to play old games very well. but for newer games u will have to play at low settings or add an agp card later.
mohit is offline
Old 14-05-2005, 07:52 PM   #7 (permalink)
dude amd 2800 64 754 + asus k8n should be abt 10.k
512mb ddr 400 corsair costs 2800+tax
hynix shd be 2200-2500 at max 2500
abt 2335-2450 might be fine
try to go for d43 chips,may be better oc didn't darklord do it beyond 250.
akshayt is offline
Old 15-05-2005, 07:42 PM   #8 (permalink)
The Hardware Labs
mohit's Avatar
@akshayt
dude the major problem with the k8n-e deluxe board is that it does not have onboard video .. this will increase his budget as he will have to buy a separate video card ... on the other hand the asus a7n8x-vm-400 has very good onboard integrated graphics based on the geforce mx 4000 chipset i think ..
@prem
where are you and what have you decided ?
mohit is offline
Old 15-05-2005, 11:56 PM   #9 (permalink)
sidewinder's Avatar
some months agoo digit named celeron "Hopeless piece of silicon" nd they r so.
If u can stretch ur budgetr 2 k more then u would get a good amd64 2800 system...good for ganing
P4 is ok but looking to ur budget amd will suit u better.
If u cant fit in amd64 then go for sempron...lot lot lot lot better than celeron nd even non ht p4s
Bombina rocks
sidewinder is offline
Old 16-05-2005, 02:04 PM   #10 (permalink)
for 20k you will not get good decent gaming
akshayt is offline
Old 16-05-2005, 11:31 PM   #11 (permalink)
I thinck 2.4C wud better on a ASUS P4P-800 E delux
it features Wifi, 8channel audio but no integerated VGA u will hav 2 buy a AGP 8x Card and I think a 128 MB Geforce 4 Ti4200 --8x GFX card wud suffice u one from MSI costs nearly 5500 bucks
It wud give more FPS than a 5700LE
[flAsh] is offline
Old 23-05-2005, 06:30 PM   #12 (permalink)
Default thank u for reply
iam an engineering student.i have 1 p3 in home.now iam in hostel i want to buy a new one.so i post that one .thanku for replys.....
i think p4 is better thAN amd 2600 .DO YOU SUGGEST BEST GRAPHIC CARD ,SOUND CARD ,SPEEKER,DIGIAL CAMERA,PRINTER & SCANER BUDJET IS 15 K.
prem is offline
Old 23-05-2005, 07:30 PM   #13 (permalink)
asus k8n shd be abt 5k
akshayt is offline
