Old 28-08-2008, 10:05 PM   #1 (permalink)
~Beating Toughest Games~
pc_game_lover2004's Avatar
Question Please Help Me Out !!!
Hi guys I recently upgraded my pc....
and the computer vendor place intel's motherboard model D945GCPE
Other details are here
now guys I want to add a graphic card of low end range just 3k
some say that graphic card is supported on my board and some say not
pls. help me...
and yes if not pls suggest a transaction by which i can sell this processor+motherboard
and buy a new one that can support graphic card
my budget jus 2.5-3k
PKG
My Rig :-Intel(R)Pentium(R)DualCPU E2160@1.80GHz, 2046MB RAM, 500 GB HDD, NVIDIA GeForce 8600 GT, Windows Vista™ Ultimate, Asus P5N-MX Motherboard
pc_game_lover2004 is offline
Old 28-08-2008, 11:24 PM   #2 (permalink)
Project Halcyon V2.0
tkin's Avatar
Default Re: Please Help Me Out !!!
pls. help me...
Nope,sorry to be bearer of bad news but your mobo does'nt have expansion slots(AGP/PCIe).Have to change your mobo.
New mobo that can support graphic card at 2.5-3.5k:-
Asus P5N MX~2.5k (supports upto quad core intel processors).
http://www.asus.com/products.aspx?mo...11&l3=614&l4=0
http://www.theitwares.com/motherboards/motherboards.htm
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline
Old 28-08-2008, 11:26 PM   #3 (permalink)
i m sorry to say my dear friend that ur board doesn't have an expansion slot for graphics ....
http://www.intel.com/products/deskto...e-overview.htm
here it says "Two PCI Conventional* bus add-in card connectors"....if there was any PCIe slot ...it would have been mentioned there ...
imgame2 is offline
Old 29-08-2008, 09:43 AM   #4 (permalink)
Well thanks for the bad news...
anyways tkin bro...
if I upgrade just my this mobo to the Asus P5N MX
then what about the processor...I'm using Intel Dual Core 1.8GHz E2160
So the processor is supported over that card or do i have to change the processor also...
PKG
Old 29-08-2008, 10:39 AM   #5 (permalink)
Excessive happiness
furious_gamer's Avatar
anyways tkin bro...
No... You dont need to change ur proccy as its LGA775 socket... So juz threw away ur Mobo and pick the ASUS P5N-MX and add any 8600GT cards that'd roughly cost around 3-3.5k and start playing.... If u see my siggy you may get why i suggest the ASUS Mobo.....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is offline
Old 29-08-2008, 11:45 AM   #6 (permalink)
tkin's Avatar
anyways tkin bro...
No prob, Go for it.
For a good graphic card go for any nVidia 8xxx series card that suits your budget.For entry level gaming nVidia's still the best. http://www.theitwares.com/gfxcards/gfxcards.htm
You may also need to upgrade the Power Supply(Atleast 400w will do)
tkin is offline
Old 29-08-2008, 05:09 PM   #7 (permalink)
Great thanks raj and tkin...
this forum is really helpful and so are its members
Thanks for ur help...
and raj bro i had seen now your sigi...
Well thanks once again...
I hope to find out the same motherboard you mentioned
PKG
Old 29-08-2008, 06:10 PM   #8 (permalink)
cooldip10's Avatar
it doesnot have a AGP/ PCIe Slot buddy... Better buy another mobo with PCIe support
Everything is Possible
cooldip10 is offline
Old 29-08-2008, 06:21 PM   #9 (permalink)
The Black Waltz
OFFTOPIC
@rajkumar_pb- is an 8600GT based card available for such a low price??!! What's the lowest costing 8600GT based card then? What's the cost of the ASUS EN8600 GT?
#krow @ irc.freenode.net
Cool Joe is offline
Old 29-08-2008, 06:32 PM   #10 (permalink)
Excessive happiness
Originally Posted by beta testing View Post
OFFTOPIC
Mercury 8600GT 3.5k+VAT and ASUS EN8600GT.. i m not sure but a bit costlier than other brand..But i m sure abt Mercury one..
PS Request
Old 30-08-2008, 09:46 AM   #11 (permalink)
thanks kooldip..
hey guys thanks for helping me out...
i will be highly thankful now if you can solve my this problem too...
Online Trading
PKG
Old 09-09-2008, 04:01 PM   #12 (permalink)
good news guys i'm upgrading my mobo to ur told Asus P5N-MX but still got confusion for graphic card...
which one good but as low as 1.5-2.5k
and what about pixel shader support...
do these offer 2.0 or 3.0 some games like vioshock and assasin's creed require pixel shader 3.0 ver....
so pls tell about that also
hey guys pls help me out on graphic card
PKG
Last edited by pc_game_lover2004; 10-09-2008 at 08:37 AM. Reason: Automerged Doublepost
Old 10-09-2008, 09:03 PM   #13 (permalink)
TooR
alok4best's Avatar
I guess XFX Nvidia 8400GT 256MB ram costs around 2400. that will be a decent card for your needs.
I wish !!
alok4best is offline
Old 10-09-2008, 09:11 PM   #14 (permalink)
Violent serenity.
Psychosocial's Avatar
^^That card sux to core.
Mercury 8600GT 256MB GDDR3 for 3k
MSI N8600GT 256MB GDDR3 for 3.5-3.7k
Psychosocial is offline
