Old 27-08-2008, 11:09 AM   #1 (permalink)
=--=l33t=--=
ring_wraith's Avatar
Default Questions about RAID 0
Thanks to the combination of my unlimited connection and Bitorrent, I find my 160GB Hard Disk Filled to the brim with eh... ah... cough..Linux Distros.
So i thought, why not get another HDD?? So i am going to buy another 160GB HDD. But I have a few questions first:
1) I wanted to set up a RAID 0 Array. What I've heard is that in a RAID 0 Array, the space you can utilize is double the space of the smallest HDD in the array. This happens to be the reason I decided to go for another 160GB and not a larger one. Is what I've heard right?
2) I actually read up a bit about RADI0 arrays and found out that data is broken into chunks which are then written on the same sector on both disks, thus allowing sort of a parallel connection. But here's the issue. A lot of my data (160 GB to be precise) is already present on one disk. So how do I go about re-distributing this data so that it is broken into chunks and stored on 2 disks? Or is this automatic?
3) Will I have to re-install Windows in order to make it utilize the added speed the RAID 0 array offers? Or can I de-fragment or something?
Homer: God bless those pagans.
ring_wraith is offline
Old 27-08-2008, 02:01 PM   #2 (permalink)
18 Till I Die............
Default Re: Questions about RAID 0
Why do you want to use RAID 0 but? AFAIK, the hassles are not really worth it. Just buy a bigger disk and store data on them both. Why bother with RAID 0?
http://www.bash.org/?258908
mehulved is offline
Old 27-08-2008, 07:04 PM   #3 (permalink)
=--=l33t=--=
^^ Coz of the performance gains!
Old 27-08-2008, 08:03 PM   #4 (permalink)
Why do you need that kind of performance gain? Any special reason? Is the performance gain worth the risk of loosing data? Cos AFAIK, RAID 0 is all lost if one disk goes kaput then if you need to recover data off it, you will need to pay a fortune to recover it.
mehulved is offline
Old 27-08-2008, 10:36 PM   #5 (permalink)
=--=l33t=--=
^^ yeah, that is right. But the performance gains are upto 25% in some cases. So that is seriously worth it. Most of my data is easily recoverable files anyway.
Old 28-08-2008, 01:43 AM   #6 (permalink)
mad_max's Avatar
1.Yes
2.No idea lol
3.Definately
but seriously bro jst buy a hd with a larger capacity and plug it into your casing unless you're into HD video editing and you can't spend extra money on those scsi disks i can't see a single good reason to use a raid0,cuz its kinda risky and the performence gains you'd see are pretty marginal
but then again i had that raid0 craze a while back so who am i to say no
mad_max is offline
Go for Raid or not joy_chak Hardware Q&A 7 15-02-2007 09:28 PM
Want info on Raid 0...Raid 5 amitsaudy Tutorials 2 16-01-2006 09:01 PM
RAID help psreesreekanth QnA (read only) 4 02-12-2005 07:28 PM
RAID digitizen Hardware Q&A 1 07-11-2005 11:06 PM
HELP HELP HELP.....RAID HELP ramu QnA (read only) 5 19-10-2004 11:47 PM
