Old 24-08-2008, 09:14 PM   #1 (permalink)
java is fun.
digitalage's Avatar
Question virtual box & actual harddisk!!?
i use virtual box in vista.
installed fedora 9 in that.
can i use my actual hard disk.. in the virtual version of OS.
digitalage is offline
Old 24-08-2008, 09:21 PM   #2 (permalink)
AFK
thewisecrab's Avatar
Default Re: virtual box & actual harddisk!!?
I didnt get your Question.
But lets see if this answers it:
When you create a Virtual HDD, the fedora files are installed on it.
This Virtual HDD file will be with some .vdi or something extention.
It will occupy the same amount of space that you might have specified when configuring the Virtual HDD.
Thus, VirtualBox uses your actual HDD to make a .vdi file which acts as your partition on your fedora 9.
I hope this is clear
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 24-08-2008, 09:30 PM   #3 (permalink)
java is fun.
digitalage's Avatar
^thanx bro but u made u misunderstand my qus....
lets make it more clear...
i have some of my files in my hard disk...
than i installed virtual os using virtual harddisk...
but now the files which i can access from my virtual os are only which are saved in virtual HDD
but i want to access the files priviously saved (not in vdd) from virtual os interface...
....hope this makes it clear...
Old 26-08-2008, 12:22 PM   #4 (permalink)
Elevating Humanity
The Conqueror's Avatar
Not possible
Regards,
The Conqueror
The Conqueror is online now
Old 26-08-2008, 04:55 PM   #5 (permalink)
The Frozen Nova
casanova's Avatar
It is possible.
Go to tutorails page. Third link should be helpful.
I had done it in some other way following a tut on this page. I am not able to find that page as of now. It is mentioned in help I guess.
www.nerdweed.blogspot.com
casanova is offline
Old 26-08-2008, 06:46 PM   #6 (permalink)
Elevating Humanity
Thanks casanova
Regards,
The Conqueror
Old 27-08-2008, 01:48 AM   #7 (permalink)
java is fun.
digitalage's Avatar
thank you man
Old 27-08-2008, 10:29 AM   #8 (permalink)
The Frozen Nova
casanova's Avatar
Welcome mates.
casanova is offline
What is my actual IP ??? passion_unlimitedd QnA (read only) 7 23-07-2007 12:41 PM
Actual consumption? kumarn_2004 QnA (read only) 5 22-12-2006 03:36 PM
Actual defination Binay 007 QnA (read only) 2 23-11-2006 09:54 AM
What is the actual size of a dvd?? thilina QnA (read only) 20 11-10-2006 04:37 PM
IS this actual speed! eagle_y2j QnA (read only) 3 24-05-2006 11:50 PM
