Old 24-08-2008, 07:40 PM   #1 (permalink)
Elevating Humanity
The Conqueror's Avatar
Default DNS Problem...
Hi All!
I have been facing problems recently ,Most websites do not resolve and i have to refresh 8-9 Times to make it resolve and load. Only the Thinkdigit and Google Apps work fine .
I am using BSNL H750 Plan but I had not faced this issue before.
Please recommend me any good DNS.Also how is OpenDNS?
Regards,
The Conqueror
The Conqueror is online now
Old 24-08-2008, 07:46 PM   #2 (permalink)
Default Re: DNS Problem...
Try Singtel DNS
165.21.83.88
165.21.100.88
cool_techie_tvm is offline
Old 24-08-2008, 07:50 PM   #3 (permalink)
Elevating Humanity
Originally Posted by cool_techie_tvm View Post
Try Singtel DNS
165.21.83.88
165.21.100.88
Works Fine Now
Thank you
Regards,
The Conqueror
Old 24-08-2008, 09:23 PM   #4 (permalink)
java is fun.
digitalage's Avatar
can someone explain me what is this DNS and how conqueror^ changed it.....
....do it works on Mobile(GPRS) networks too.... can i speed up online speed with it...
thanx in advance
digitalage is offline
Old 25-08-2008, 12:09 PM   #5 (permalink)
Elevating Humanity
It is Recommended to change DNS Only when either you are getting less browsing speed than normal OR the sites are not loading,ie not resolving.
Which OS Do you use ? The steps are different for each OS
Above all, the DNS makes it possible to assign domain names to organizations independent of the physical routing hierarchy represented by the numerical IP address. Because of this, hyperlinks and Internet contact information can remain the same, whatever the current IP routing arrangements may be, and can take a human-readable form (such as "example.com"). These Internet names are easier to remember than the IP address 208.77.188.166. People take advantage of this when they recite meaningful URLs and e-mail addresses without caring how the machine will actually locate them.
The Domain Name System distributes the responsibility for assigning domain names and mapping them to IP networks by allowing an authoritative name server for each domain to keep track of its own changes, avoiding the need for a central register to be continually consulted and updated.
Regards,
The Conqueror
Last edited by The Conqueror; 25-08-2008 at 12:10 PM. Reason: Automerged Doublepost
Old 25-08-2008, 01:48 PM   #6 (permalink)
java is fun.
digitalage's Avatar
^^Thanx a lot for the information....
- i am using Vista. and nokia PC suit to connect to internet.
Old 25-08-2008, 02:01 PM   #7 (permalink)
Elevating Humanity
To Change your DNS :
Open Network Connections by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, and then clicking Manage network connections.
2. Right-click the connection that you want to change, and then click Properties. Administrator permission required If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3.Click the Networking tab. Under This connection uses the following items, click Internet Protocol Version 4 (TCP/IPv4)
4.Now,To specify DNS server address settings, do one of the following:
•To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
Click OK then Click Close
Regards,
The Conqueror
Old 25-08-2008, 02:08 PM   #8 (permalink)
java is fun.
digitalage's Avatar
thanx bro....
-not changed the speed a lot though.
-but happy to have this information.... thanks again.tc
Old 25-08-2008, 02:17 PM   #9 (permalink)
Elevating Humanity
Originally Posted by digitalage View Post
thanx bro....
Welcome
As I said Earlier, Changing the DNS is only required if you are experiencing that the sites do not Open or you are getting slow speeds than usual.
Regards,
The Conqueror
Old 25-08-2008, 03:02 PM   #10 (permalink)
18 Till I Die............
Originally Posted by The Conqueror View Post
Welcome
And switching to a more secure nameserver if your current one isn't. See http://www.doxpara.com/ for one.
http://www.bash.org/?258908
mehulved is offline
Old 25-08-2008, 04:35 PM   #11 (permalink)
Elevating Humanity
Nice Site.
So which is the Most Secure DNS Name Server?
Regards,
The Conqueror
Old 25-08-2008, 04:46 PM   #12 (permalink)
OpenDNS is secure from this vulnerability. I prefer to use my own local DNS server for many reasons thus am unaware of other options around.
mehulved is offline
Old 25-08-2008, 06:11 PM   #13 (permalink)
Elevating Humanity
Thanks for info
Regards,
The Conqueror
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
