Old 24-08-2008, 12:53 PM   #1 (permalink)
Default Disk Defrag Issue
Hi All,
I have noticed a pretty weird behavior wrt my hard disk. I have 5 partitions on a 160 GB HDD.
My C: drive tends to get fragmented very quickly (sometimes in just 2 days). I use O&O Defrag and whenever i analyse the disk the fragmentation level comes upto atleast 15 -16%.
The C: drive has only windows on it. Other apps are all installed in the other partitions..
Can someone help me here, since this is causing my pc to slow fown significantly...
Thanks!
rakesh14021983 is offline
Old 24-08-2008, 02:09 PM   #2 (permalink)
Default Re: Disk Defrag Issue
Are my documents and desktop etc. in C drive or on other?
Remove temporary files, empty cache, Use CCleaner.
ThinkFree is offline
Old 24-08-2008, 03:06 PM   #3 (permalink)
I use CCleaner, TuneUp Util 2008, SpyBot Search n Destroy... with all latest updates.. scans are run every single weekend hence temp files shud not be an issue...
Any ideas?
Old 24-08-2008, 03:10 PM   #4 (permalink)
Do you see the same level of defragmentation in windows disk defragmentar as well?
Old 24-08-2008, 04:55 PM   #5 (permalink)
Unfortunately, yes i do...
Old 24-08-2008, 09:06 PM   #6 (permalink)
Move pagefile to another partition, disable hibernation restart, and then defragment. May help
Old 24-08-2008, 09:10 PM   #7 (permalink)
I would suggest booting into the recovery console and running chkdsk
cool_techie_tvm is offline
Old 24-08-2008, 09:16 PM   #8 (permalink)
java is fun.
digitalage's Avatar
did u try to defrag in safe mode?
digitalage is offline
disk space issue legolas QnA (read only) 9 16-09-2007 06:48 AM
mother board and hard disk issue manoranjan sahoo Hardware Q&A 6 02-07-2007 10:20 PM
UPDATE: Auslogics Disk DefragŪ 1.1.2 released <Free Download> Kiran.dks Technology News 9 27-01-2007 12:01 AM
Hard Disk-Motherboard Compatibility Issue TransvaC Hardware Q&A 1 02-07-2006 03:27 PM
disk defrag problem dhawald QnA (read only) 5 09-03-2006 06:52 PM
