Old 24-08-2008, 12:08 AM   #1 (permalink)
Default what happens if I don't replace my mothboard battery?
Hi Guys,my motherboard battery has gone dead because each time I start my system it takes me to the year 2000,I don't want to replace it as I don't mind setting the clock right again.
I hope it does not affect any other application or devices?is it fine to leave a dead battery in the motherboard
2.is there any way to recharge it without opening the cpu?
thank you
viruses is offline
Old 24-08-2008, 12:54 AM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: what happens if I don't replace my mothboard battery?
hey............dont b afraid................nothing will happen if u change ur battery...........
no there is no option to recharge it.......
the battery is used to power the BIOS ROM so that data does not get deleted when u power off the CPU................maximum that can happen that is ur BIOS will be restored to factory settings...............nothing more than that............change it.............don't worry................
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
Old 24-08-2008, 01:33 AM   #3 (permalink)
Adding to krishnandu's reply:
Besides the clock, you will lose any settings you change from BIOS, such as the amount of graphics memory for onboard video, boot sequence, etc. Also, after a long time, a dead battery may leak and cause corrosion of some motherboard component.
Motherboard BIOS battery is cheap and easy to replace. If you don't feel up to doing it yourself, just take your CPU to a computer shop and ask them to do it. It takes just a minute.
pimpom is offline
Old 24-08-2008, 06:50 AM   #4 (permalink)
The Boss
aytus's Avatar
besides the BIOS settings .. sometimes windows may refuse to boot... if you dont set the time correctly . some secure websites will refuse to open...
besides rather then buying the battrey from some pcwalla .. u should go to some watch-walla,s shop and thr u shud be able to get this battrey .. approximate price RS. 30
take the battrey out of ur mobo and show it to him and tell him to give you a similar one
G3N10U5 BY B1RTH, HACK3R BY CH01C3
E5200; Biostar P43-A7; Palit GF 9600GT; Corsair 4GB; CM extreme power 390W
aytus is offline
Old 24-08-2008, 01:58 PM   #5 (permalink)
thanks guys,much appreciated
viruses is offline
String.replace estranged12 Programming 2 09-04-2008 09:58 AM
ups battery gone, how much does 600va battery cost? fallin_a Hardware Q&A 7 14-01-2008 01:28 PM
Should i replace the new cpu fan? New CPU / Motherboards 6 03-01-2008 07:58 AM
