Old 23-08-2008, 04:10 PM   #1 (permalink)
Default Trouble (sending And Recieving Data)
GUys got a big problem..........my internet keeps sending data and recieving data.....lol.......scanned with lavasoft ad-awaare PRO (cant tell ya how i got it) but nothin comes up ......nothing wrong with background processes......all are normal ones.......can't use spyware doctor and mcaffee as i'm using 64BIT version of XP(HARDCORE GAMER).........help guyz
Dushy_smartguy is offline
Old 23-08-2008, 04:44 PM   #2 (permalink)
paroh's Avatar
Default Re: Trouble (sending And Recieving Data)
There are many cases that are common.
1)Like windows is updating
2)Antivirus is updating
3)Adware or spware is updaing
And if u are using broadband and using bridge type connection there will be some data transfer but it is limited to local loopback
as if u get 256kbps connection u would get max 32KBPS speed but if u are conecting through bridge it will show 56KBPS. but in reality u are getting 32KBPS and 34KBPS is used for local loop back
paroh is offline
Old 23-08-2008, 06:33 PM   #3 (permalink)
Elevating Humanity
The Conqueror's Avatar
Also it can be that any software which you have installed is updating.
It could be Adobe Updater or anything else.
Regards,
The Conqueror
The Conqueror is online now
Old 23-08-2008, 06:58 PM   #4 (permalink)
adi007's Avatar
Use comodo firewall
U can track any net access request
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
Old 25-08-2008, 02:05 PM   #5 (permalink)
thanx guyz, but there is no update running of any program in the background...........newayz i'll try using COMODO FIREWALL ......hope i come to know what's really goin on?
Old 25-08-2008, 02:27 PM   #6 (permalink)
Elevating Humanity
Yes, Also if you can Get Kaspersky Internet Security 2009 Trial Version.
Install it (it is free 30daytrial) ,Now Run a FULL Scan on your system.Remove any threats detected.Its Firewall will also monitor your internet and report which Software is Sending/receiving Data.
By the way, I recommend Kaspersky Only because I myself use it and I have found it to be good when compared to other Antivirus/Firewall Softwares
Regards,
The Conqueror
What Softwares/techniques data recovery professional use to recover data from HDD ? CadCrazy Software Q&A 1 10-08-2007 10:01 AM
Software for sending and recieving sms ashfame Software Q&A 4 06-04-2006 01:12 AM
My Gmail not recieving Mails from other gmails!!! club_pranay Software Q&A 2 26-10-2005 09:41 AM
Fedora Core 4 installed ...... trouble trouble trouble... iinfi Open Source 19 12-10-2005 06:03 PM
RECIEVING PHONE CALL ! vijaythefool Mobiles and Tablets 5 29-01-2005 05:20 AM
