Old 23-08-2008, 03:32 PM   #1 (permalink)
Exclamation Command Prompt Problem
Friends ...
recently i tried to run command prompt through "Run window" by typing "cmd"..
it opened a folder named "cmd" instead of opening the command prompt...
is it a virus or not...
In both the cases what should i do??? i m not able to open command prompt
pls help...
thanx in advance...
!> I-I /-\ \/\/ /-\ l_
dhawalsant is offline
Old 23-08-2008, 03:38 PM   #2 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Re: Command Prompt Problem
First scan ur PC with an antivirus.
Try typing "command" in run.
Or else, goto Accessories and click on command prompt.
Blogging at:
Technostarry
saqib_khan is offline
Old 23-08-2008, 03:43 PM   #3 (permalink)
buddy ...
i have already done this n then posted this post...
ne other solution..
Old 23-08-2008, 04:18 PM   #4 (permalink)
Save the WORLD !!!
Kulz's Avatar
It might just be a virus... try this link :- http://tec-updates.blogspot.com/2007...oval-tool.html
Save the WORLD
Kulz is offline
Old 23-08-2008, 04:52 PM   #5 (permalink)
paroh's Avatar
U can try to scan for spware. Try free spybot and update its defination to latest and scan ur computer with it .
http://dl.betanews.com/spybotsd160.exe
paroh is offline
Old 04-10-2008, 12:41 PM   #6 (permalink)
ur pc have infected by any busterd virus,But dont worry go google and solve ur prb
Nir ur friend
nirjhar is offline
Old 04-10-2008, 01:17 PM   #7 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Try running "cmd.exe"
dheeraj_kumar is offline
Command Prompt Problem vaibhavtek QnA (read only) 5 27-11-2007 09:56 PM
Command Prompt Help rishi1 QnA (read only) 2 20-07-2006 11:05 AM
command prompt problem bukaida QnA (read only) 2 22-01-2006 08:26 PM
Command prompt in xp suresh4ever QnA (read only) 1 10-01-2005 05:13 PM
