Old 23-08-2008, 01:57 PM   #1 (permalink)
Will Power
TheLetterD's Avatar
Default Best pc within 25000
ppl heres the best gaming pc u can build within 25k using:
Intel C2D e7200
HRDDSK 160gb
pls comment
TheLetterD is offline
Old 23-08-2008, 02:03 PM   #2 (permalink)
AFK
thewisecrab's Avatar
Default Re: Best pc within 25000
Have a look at this:
Basic Guide Purchase a New System
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 23-08-2008, 02:49 PM   #3 (permalink)
I M A *STAR*
saqib_khan's Avatar
@dipesh8thgrade
U r going right. U can buy Intel C2D e7200 & HRDDSK 160gb in that budget. Also consider a mobo with gud chipset. If budget permits then buy 2 GB of RAM .
Blogging at:
Technostarry
saqib_khan is offline
Old 27-08-2008, 08:55 PM   #4 (permalink)
Will Power
TheLetterD's Avatar
THANKS A ton for ur help ppl!! im new to digit forum.want help?post me & ill always reply to u.
A Decent CPU for 25000, Possible?? HellKing Hardware Q&A 3 17-07-2008 09:30 PM
Suggest a Laptop under 25000 rksingh Laptops and Netbooks 26 09-07-2008 05:00 PM
Wanted a Config for PC under Rs.25000 Radhesh Bhoot PC Components / Configurations 8 04-09-2007 01:50 PM
Best PC within 25000/ namelesswarrior Hardware Q&A 9 15-07-2007 12:55 PM
Rs. 25000 pC megacoolxs QnA (read only) 1 16-09-2005 07:37 PM
