Old 12-05-2005, 03:20 PM   #1 (permalink)
ASH_DSG
Posts: n/a
Default HOW TO CONVERT 24 BIT GRAPHIC TO 32 BIT
HI,
I HAVE A GA6IWFE MOBO WITH BUILT IN GRAPHIC INTEL 810 CHIPSET. MY GRAPHIC SHOWS ONLY 24 BIT GRAPHIC COZ OF THIS I CAN'T PLAY GAMES WHICH RUN ON 32 BIT GRAPHIC. HOW COULD I CHANGE 24 BIT TO 32 BIT CAN U TELL ME HOW COULD I CHANGE IT TO BY USING SOME SOFTW OR INTERNAL REGISTER SETTINGS.
OR CAN U TELL A PCI GRAPHIC CARD TO PLAY GAMES LIKE HALO & NFSUG2.
THANKS.
Old 12-05-2005, 06:15 PM   #2 (permalink)
NikhilVerma's Avatar
Sorry you can't because you GPU doesn't support 32 bit depth......
You can try 3d analyse but don't expect it to work
www.tommti-systems.de/start.html
NikhilVerma is offline
