Old 12-05-2005, 02:48 PM   #1 (permalink)
Curious Guest's Avatar
Default XP TCP/IP Repair
XP TCP/IP Repair
Is Spyware and/or Adware messing up your internet connection after you
have uninstalled it?
Has your internet connection slowed down and you just don't know why?
Have you used an Internet Optimizer that just didn't optimize your internet,
instead it made it slower?
If you answered yes to any of the questions above, then XP TCP/IP Repair
may help fix your internet connection and possibly even protect your privacy.
XP TCP/IP Repair is a Graphical User Interface (GUI) for commands in
Windows XP® that repair your TCP/IP registry settings and your Winsock
LSP's.
Instead of having to remember long confusing command line commands you
can now just click a button.
XP TCP/IP Repair Download
http://www.xp-smoker.com/downloads/xptcprep.exe
_____________________________________
THE HELL IS FULL SO I AM BACK WITH DIGIT.
Curious Guest is offline
Old 22-05-2005, 01:19 AM   #2 (permalink)
will check it out !!!
thanx !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 23-05-2005, 05:28 PM   #3 (permalink)
downloaded .... will check it out as soon as i mess up sumthing bad with my net connection i order to juice out that extra speed...!!
grinning_devil is offline
Old 23-05-2005, 06:27 PM   #4 (permalink)
GameAddict's Avatar
Default The thingie worked on my Win 2000 Prof. too
The above repair utility worked on my Windows 2000 Prof. too.
GameAddict is offline
