Old 21-08-2008, 12:38 PM   #1 (permalink)
rohitshubham's Avatar
Default over clocking/Latency
hey
What IS over Clocking AND Latency?
and what devices can be overclocked
can i overclock them
1. NVIDIA GeForce FX 5200
2. DDR1 PC3200 Ram
rohitshubham is offline
Old 21-08-2008, 03:48 PM   #2 (permalink)
Elevating Humanity
The Conqueror's Avatar
Default Re: over clocking/Latency
Latency is the time delay and also called as PING . It is mostly measured in ms. Typically,For gaming Pings from 20-300 are considered as playable.
Overclocking means that you are increasing the stock clock speeds with whatever you want.This can mean a added boost to your processing/GPU card's Power but keep in mind that you need to cool your product and it voids the warranty.
More information on these topics :
http://en.wikipedia.org/wiki/Latency
http://en.wikipedia.org/wiki/Overclocking
Yes you can overclock your graphics card using a software such as ummm Riva Tuner.Google for more options.
I think it would be a little bit Risky to overclock your RAM, also in computing terms, you should never Write RAM as Ram .
Regards,
The Conqueror
Last edited by The Conqueror; 21-08-2008 at 03:50 PM. Reason: Automerged Doublepost
The Conqueror is online now
Old 22-08-2008, 10:47 AM   #3 (permalink)
Thanks
Old 22-08-2008, 11:15 AM   #4 (permalink)
Elevating Humanity
Welcome
Regards,
The Conqueror
core 2 duo E6420 over clocking !! a_k_s_h_a_y QnA (read only) 1 23-07-2007 08:46 AM
Over Clocking help codename_romeo Hardware Q&A 13 27-11-2006 07:51 PM
Is over clocking safe? speedyguy Hardware Q&A 18 30-01-2006 02:04 PM
Help with Over Clocking! Plz.. Satissh S QnA (read only) 8 09-08-2005 11:58 PM
How Is it Clocking! damnthenet QnA (read only) 1 14-05-2005 02:57 PM
