Old 12-05-2005, 11:49 AM   #1 (permalink)
Just Do It
Charley's Avatar
Default Hidden hard drive.
I have a drive that is hidden. It is a standalone drive and not partitioned. How do I bring it up. I could use that to store data.
Suggestions welcome.
Charley is offline
Old 12-05-2005, 01:20 PM   #2 (permalink)
1st of all check ur JUMPER setting on ur hard drive !!! 2nd if ur using win98 u shall have this problem ! coz even i have not come to a conclusion on this problem 3rd if u have win xp it sould b detected if ur jumper sttings are right!!!
King_Niral is offline
Old 12-05-2005, 02:33 PM   #3 (permalink)
Just Do It
Charley's Avatar
Dude this drive was hidden by the engineer cos it had bad sectors, I was using it before. BTW how do i check where the jumper is[is it in the cabinet] & i have win98 se installed
Charley is offline
Old 12-05-2005, 06:17 PM   #4 (permalink)
Default JUMPER SETTING AT THE BACK !!!
the jumper is always behind the drive (usually 6- 8 copper pins in a rectangle varies form company to company ) there should be a jumper setting manual inscribed on the top of ur drive !!! u can read it and change the setting !!!
Old 19-05-2005, 01:58 AM   #5 (permalink)
u did not get back on this !!! Did u find the jumper switch !!!!
Old 19-05-2005, 02:01 AM   #6 (permalink)
expertno.1's Avatar
i have c: as 98 fat32 and d: as ntfs
which software will allow me to view contents of dL in 98 ?
expertno.1 is offline
Old 19-05-2005, 02:02 PM   #7 (permalink)
Just Do It
Charley's Avatar
Nope, havent. Pls gimme the exact sequence to follow .......
Charley is offline
Old 19-05-2005, 02:44 PM   #8 (permalink)
i can help on jumper suff. take out ur hard disk. take it out from cabinet and see the back. u can find few smaaaall pins. read the jumper postion figure on the hard drive sticker on top n u ca figure the right thing out.
ur secondary drive has to be set as "slave" whose corres. jumper position can be found on sticker itself.
reading the sticker n taking hard disk out to see things urself can help u a lot.
good lucks
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 19-05-2005, 06:47 PM   #9 (permalink)
i believe rather than the whole HDD just a partition is hidden..
and dude if it is because of bad sectors don't mess with it..
still if you use win xp right click on "My Computer"
click manage
choose removable drive management
HItesh Gupta
There are only 10 type of people in world...
1 who understand binary..
1 who don't
hitesh_hg is offline
Old 19-05-2005, 09:44 PM   #10 (permalink)
expertno.1's Avatar
try partition magic and see if it shows the hidden partition or not
Old 19-05-2005, 10:50 PM   #11 (permalink)
QA Juggler
saROMan's Avatar
Use NTFS Reader ..info Here
Download Here
now ur prob..u said ur engg hide it...u said its standalone ...so chk if he has removed the connections to make it hidden ....also install tweakUI ..and see the drives status to see if any drive is given in the list but not presend actually in ur my comp....(except a:/b: and ur CD rom Drive)
whatz the company name of ur hdd ??
herz a list chk ur hdd Jumper setting here here
Hitachi
Samsung
Seagate
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 20-05-2005, 12:48 PM   #12 (permalink)
Just Do It
Charley's Avatar
click manage
HItesh Gupta
WIN 98 SE here.....
Charley is offline
Old 20-05-2005, 02:19 PM   #13 (permalink)
HEY another suggestion transfer all important data to another hard disk and LOW LEVELK FORMAT ur hard disk !!!
U should get ur LOW LEVEL FORMATER FROM the site of ur HARD disk MANUFACTURER !!!
USE GOOGLE ITS THE BEST !!!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
Old 20-05-2005, 03:16 PM   #14 (permalink)
Er... I can't understand wat do u mean by hidden here??
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
thecyclone2k is offline
Old 20-05-2005, 05:02 PM   #15 (permalink)
Just Do It
Charley's Avatar
For what & how will that help me. Dude I'm trying to figure out how to unhide my hard drive which is hidden and ur telling me somethind else.
Charley is offline
Old 20-05-2005, 07:56 PM   #16 (permalink)
So till now has'ntthe jumper setting link helped u !!! posted by saROMan !!!
NE way EXPLAIN WAT HAVE U DONE AND WAT DO U UNDERSTAND BY UR PROBLEM !!!!
THEN MAY BE WE ALL CAN HELP U !!!!
CHEERs
TAKE CARE !!!!
Old 20-05-2005, 08:40 PM   #17 (permalink)
expertno.1's Avatar
this is really a bit complicated guys
can achacko@dataone.in explain what he had done from the begining ?
Old 20-05-2005, 11:59 PM   #18 (permalink)
Hey Check if ur Power Connector is Connected Or Not ????????
Old 21-05-2005, 12:18 PM   #19 (permalink)
Just Do It
Charley's Avatar
For Gods sake look at the 1st post of the thread.
It says the drive was hidden cos of the bad sectors, I wanna unhide it now as I have free space on it.
Charley is offline
Old 21-05-2005, 01:28 PM   #20 (permalink)
QA Juggler
saROMan's Avatar
bud.....did u chked my solution.....plz reply what have u done.....ur problem solved/not solved etc...
saROMan is offline
Old 21-05-2005, 04:13 PM   #21 (permalink)
LETZ MAKE THIS EASIER DO U SEE THE HDD IN UR BIOS ????
Old 21-05-2005, 05:10 PM   #22 (permalink)
Your query was
'I have a drive that is hidden. It is a standalone drive and not partitioned. How do I bring it up. I could use that to store data.'
Clarify what according to you means 'HIDDEN'.
There can be various interpretations.
I interpret it as physically connected to the computer but hidden in the OS
If thats what you mean then check if the disk is detected in your bios.
If yes then boot into windows.
You said it is a single drive with no partitions but maybe you mean it does not have multiple partitions cos there has to be one primary partition for the disk to function(ie c and depending on your OS you will have to unhide that partition.
If you are using windows XP you can do it in explorer from the manage option(search the forum for clues)
If u are running win9x then use any third partu utility like Partition magic etc and make the only partition on the 2nd hdd visible.
Beware win9x does not support multiple primary partitions but it is unlikely to have any problems.
As you said ur engineer had hidden the disk due to bad sectors
so after rebooting run fdisk and delete the partition on the second disk and
again recreate it.
REboot in msdos mode and perform a full format on the raw partition with the file system fat/fat32 etc.
Scan the partition for errors using scandisk .
Perform a complete surface scan.The bad sectors will be marked and the
drive would be ready for storing data.
If the disk is physically disconnected then reconnect the ide cable and power.Ensure that there is no conflict ie. If ur connecting 2 disks make sure one is master n the other is slave. Boot from the first hdd and the new partition will be available in my cmputer.Run a through surface scan with scandisk in windows to mark the bad sectors.
amitsaudy is offline
Old 21-05-2005, 05:35 PM   #23 (permalink)
Your query was
again recreate it.
amitsaudy Has given the answer !!!
There is not better reply to ur Question !!!
Old 21-05-2005, 07:08 PM   #24 (permalink)
Just Do It
Charley's Avatar
Right&Exact.
Right, no partitions only a disk[1.4GB]
@ Saroman - Dude, tried it but doesnt work out.
Charley is offline
Old 21-05-2005, 11:50 PM   #25 (permalink)
did wat amitsaudy wrote help???
