Old 12-05-2005, 11:42 AM   #1 (permalink)
Just Do It
Charley's Avatar
Default Problem. Pls gimme a soln
I get this weird problem when the computer comes up to the dektop. It opens IE automatically & gives me the following error. It happend when I was installing ARES, WAREZ[instead of term Explorer it was ARES & WAREZ]
This prog has performed an illegal operation and will be shut down.
EXPLORER caused an invalid page fault in
module <unknown> at 0000:61b85cf6.
Registers:
EAX=0042bf62 CS=0167 EIP=61b85cf6 EFLGS=00010217
EBX=8161a8d4 SS=016f ESP=0080ff88 EBP=0080ff98
ECX=c14c1850 DS=016f ESI=0042b9f3 FS=23d7
EDX=8161a934 ES=016f EDI=8161b538 GS=0000
Bytes at CS:EIP:
Stack dump:
0042ba07 0042bf62 8161a934 0042b9f3 0080ffcc bff88f20 00000000 8161b538 00000008 8161a8d4 00000007 0080ffa4 0080fdb8 ffffffff bffc05b4 bff79050
Charley is offline
Old 12-05-2005, 01:18 PM   #2 (permalink)
swatkat's Avatar
Hmm...Do you get this error frequently? Try this, go to Start> Run and type sfc and press ENTER. Then click "Start". If the System File Checker finds any corrupt/missing files, restore it from Win98 CD or Setup files.
http://swatrant.blogspot.com/
swatkat is offline
Old 12-05-2005, 02:27 PM   #3 (permalink)
Just Do It
Charley's Avatar
Not frequently. I got it this time after the spyware affected my system
Charley is offline
Old 12-05-2005, 03:09 PM   #4 (permalink)
swatkat's Avatar
Perform an online virus scan at Panda, and save it's log and post back the content of the log.
http://www.pandasoftware.com/activescan/
swatkat is offline
