Old 12-05-2005, 11:28 AM   #1 (permalink)
Default VOB CUTTER OR DVD CUTTER
Any one got good software to cut a part of dvd or vob file and convert to diffrent formats like a vcd cutter ?
vijaythefool is offline
Old 12-05-2005, 01:00 PM   #2 (permalink)
You can Super DVD Ripper for cut DVD files
kmvinodkm is offline
Old 12-05-2005, 02:20 PM   #3 (permalink)
I use Chopper XP for cutting a part of DVD/VOB file.
Get it here http://www.digital-miner.com/chopperxp.html
Chopper XP does not change the format. It only removes the part of the file that you want in VOB format. Use some other software to change the format.
drvarunmehta is offline
Old 12-05-2005, 03:03 PM   #4 (permalink)
Just Do It
Charley's Avatar
chopper is good , i have used that before
Charley is offline
Old 13-05-2005, 10:27 AM   #5 (permalink)
Thx every one . i came around virtual Dub mod its better and easy too
. it can cut a vob and compress to any other format and can use divx too
here is the link
http://jaist.dl.sourceforge.net/sour..._inclusive.zip
And its free toooo
Old 13-05-2005, 12:18 PM   #6 (permalink)
Just Do It
Charley's Avatar
Can Virtual Dub be used for audio files also?
Charley is offline
Old 14-05-2005, 07:17 PM   #7 (permalink)
u can avoid the video if u want
