Old 12-05-2005, 01:54 AM   #1 (permalink)
Default MP3 to WAV or vice versa
Hey guys do u know any free mp3 to wav converter having some edit option to lower down the wav setting.............
If any then suggest
waiting
abhinav :roll: :roll: :roll: :roll:
abhinav is offline
Old 12-05-2005, 02:10 AM   #2 (permalink)
Can you tell us why you want to convert from MP3 to WAV? It's not like you're going to gain any quality by doing so.
drvarunmehta is offline
Old 12-05-2005, 02:55 AM   #3 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
did you tried dbpoweramp
it is the best for sound tracks converstion
rollcage is offline
Old 12-05-2005, 09:19 AM   #4 (permalink)
whoopy_whale's Avatar
Yes,dBpowerAMP is the best!!!
Often called the Swiss Army Knife of audio, dMC can digitally rip sound from audio CDs to a multitude of formats. Convert from one format to another while preserving ID tags. Nearly every audio type is supported, including MP3, MP4, Windows Media Audio (WMA), Ogg Vorbis, AAC, Monkey's Audio, and FLAC (with optional installs from Codec Central). For Windows Explorer integration, right-click Convert To and pop up useful information on audio files (such as bit rate and length). Record from LPs with Auxiliary Input.
Version 11.0 features the standard inclusion of Auxiliary Input and File Selector; a higher-quality MP3 decoder (LAME 3.96.1); support for 32-bit WAV IEEE; Unicode tagging transfers; a Power Pack trial included as standard and a license for the MP3 encoder in the trial; smart-install codecs; and new DSP effects (a graphic equalizer and dithering-down bit depth). Finally, dBpowerAmp can supply column information in Windows Explorer (much more refined than Windows standard audio columns).
Download here
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 12-05-2005, 10:06 AM   #5 (permalink)
sourav's Avatar
Use CDex or if have Nero 6.3 then you convert any audio any format but you cannot convert wma but you can convert to wma.
Or else you Jet audio came with digit.
sourav is offline
Old 12-05-2005, 11:02 AM   #6 (permalink)
tuxfan's Avatar
dbPowerAmp is the best and every now and then keeps appearing in Digit CD/DVD. So you don't even need to download it.
It can even convert yo OggVorbis which is an open standard. So if tomorrow MP3 get entangled in some legal issues, you still can listen to your music by converting your files in Ogg format. WinAmp too has a Ogg plugin
tuxfan is offline
Old 12-05-2005, 11:06 AM   #7 (permalink)
dbPowerAmps the best. I'm using it for the same reason cos i have a discman which doesn't play mp3s. Only wavs
SatishSays.com
twitter.com/satishsays
devilhead_satish is offline
Old 12-05-2005, 11:16 AM   #8 (permalink)
Location: don't drink and drive you might spill your beer
drvarunmehta said: Can you tell us why you want to convert from MP3 to WAV? It's not like you're going to gain any quality by doing so.
Maybe, he has a CD player which does not support MP3
pakkasir is offline
Old 12-05-2005, 11:30 AM   #9 (permalink)
Tux
Posts: n/a
NERO WAVE EDITOR DOES IT.
Old 12-05-2005, 03:22 PM   #10 (permalink)
Just Do It
Charley's Avatar
I tried dbPowerAmps last week , its nice and easy to use.
Charley is offline
Old 12-05-2005, 03:36 PM   #11 (permalink)
If he wants to make an audio CD, he need not convert to WAV. Just start Nero and choose Audio CD. Choose the MP3's that you want and Nero will automatically convert them to WAV.
