Old 18-08-2008, 09:34 PM   #1 (permalink)
ajayritik's Avatar
Default How to backup critical data on a DVD so that nobody can access it without permission
I have some couple of files which I need to burn on a cd/dvd and also I don't want anybody to view the files unless he enters some password or something like that. There are some friends of mine who may drop into my place and play my cd's so I want to maker sure that nobody is able to view the contents. Long back I heard about something called Gate Folder software. Is there any specific software which will help me with regards to this? I'm sorry if this question is too silly to ask.
ajayritik is online now
Old 18-08-2008, 09:55 PM   #2 (permalink)
hmmmmmmmmmmmmm's Avatar
Default Re: How to backup critical data on a DVD so that nobody can access it without permiss
jus make it rar wit passrd man...
Sellin Rapidshare Account 30 Days Validity for 6 $ PM ME
hmmmmmmmmmmmmm is offline
Old 18-08-2008, 10:44 PM   #3 (permalink)
ajayritik's Avatar
But I want to create a folder having all these files and make the folder protected. Is it possible? Here I can create rar file for a file. I'm not sure if we can make the folder as well.
Old 18-08-2008, 11:38 PM   #4 (permalink)
Elevating Humanity
The Conqueror's Avatar
Have you Tried Folder Lock?
I Guess rar would be the best option.
Regards,
The Conqueror
The Conqueror is online now
Old 19-08-2008, 12:45 AM   #5 (permalink)
The High 5 Flyer
sam9s's Avatar
Folder Lock is the ans. It can Lock your ROM drives as well. Once locked though you can view the drive in the explorer, but you cannot view the contents of any disc inserted in to the drive......very neat and nifty feature.
sam9s is offline
Old 19-08-2008, 10:30 AM   #6 (permalink)
Swalpa Adjust Maadi
RaghuKL's Avatar
If your dvd writer supports securdisc, you can use to password protect your data on dvds. LG H55N is one such drive.
if you have noticed this notice you will have noticed that this notice is not worth noticing
TRUTH IS OUT THERE
Do right and fear no man.
In word without walls, is windows (7) really needed?
RaghuKL is offline
Old 19-08-2008, 10:06 PM   #7 (permalink)
Lets Do It!
amrawtanshx's Avatar
+1 for Folder Lock.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
data backup from busy to tally jatt Software Q&A 8 07-06-2009 03:29 PM
Suggest a Good Software for Data Backup.. Jags Software Q&A 7 28-11-2008 06:30 PM
How to backup data? Dark Star Open Source 35 24-07-2008 10:57 AM
Data Storage & its backup ??? ax3 Chit-Chat 15 27-06-2008 12:47 PM
Safe way 2 backup data? best compression soft? ankushkool Software Q&A 3 09-06-2008 12:22 PM
