Hello Guyz
I have a dvd region problem.My dvd rom can read any dvd's that i write but it cannot read
the dvd's that come free with digit as well as chip magazine.I googled for this problem and
i came to conclusion that its the problem of dvd region.
My current DVD region is set to 1.Now when i try to change my dvd region
then it says
"DVD Region Change Error
Unable to update region setting.Please make sure the drive contains a region 5 media and you have administartion
privilege"
I'm absolutely sure that i have admin privilege.i even tried it to change it while disabling the drive but after i disable the drive
dvd region tab dissapears.
When i tried to change it in safe mode then also i recieve the same error.
I also tried softwares like DVD REGION FREE + CSS but the result is same.
I also read that this technique is used to prevent privacy and i have already read about encoding stuff.
But i live in INDIA and i bought my laptop here only.
I also learned that i should upgrade my dvd firmware but i cannot get updated firmware anywhere.
I also compared my & my fathers laptop registry but everything under IDE was same.
I Would also like to know that if i install 98se on my m/c then will this prob avail because if i'm right then this technology was evolved in 2004 so it should work on 98se.
plz help me.Thanks in advance
My M/c Configuration is
WinXP sp2
256 mb ram
Intel (R) 852/855 GM/GME Chipset
Philips CDRW/DVD CDD5263
plz help me.Thanks in advance.
