I want to make a .bat file
which will
Copy this folder
C:\Documents and Settings\All Users\Application Data\Kaspersky Lab\AVP8\Update distribution
and compress it (using 7-Zip / Default XP's compressing program)
and then copies it to G:\ (which is location of my flash drive.)
please suggest me the code / command line that I need to write in the notepad
and make a .bat file.
Thanks in advance.
why I want that?
I've a laptop with internet connection
And a PC with no internet/LAN.
On Both I am running Kaspersky internet security and I need to
copy the update distribution files from laptop to pc every now and then via pendrive (flash drive).
