Old 16-08-2008, 12:03 AM   #1 (permalink)
Evolving Rapidly...
confused's Avatar
Default Is there any way to hide entire hard-disk partitions???
thanks for reading.
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
confused is offline
Old 16-08-2008, 12:19 AM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Default Re: Is there any way to hide entire hard-disk partitions???
Yes .. You can use TweakUi for that .. In TweakUi > My Computer > Drives >
Whichever drive you'll unselect wont be visible in My Computer but you can access it using Run > E: {Press Enter} or Explorer address bar ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 16-08-2008, 12:27 AM   #3 (permalink)
Evolving Rapidly...
confused's Avatar
cool ..... it works.
thanks man.
confused is offline
Old 16-08-2008, 12:34 AM   #4 (permalink)
Rubik's Uncle!!
Charan's Avatar
You can also remove the drive letter which will make the hard disk totally hidden. This is
Goto
computer managment > Disk Managment > right click on the drive you want to hide > Change Drive Leter and path > remove > yes..
This will make the drive totally inaccessable. to enable it again do the same but this time just add a new drive letter than removing it.
Charan is online now
Old 16-08-2008, 02:16 PM   #5 (permalink)
Thanks. This info will probably help me too.
I have some questions though.
(1) Using TwekUI it seems that the drive will be accessible from Run > E: or Explorer address bar, which means that even a software can use the drive to access files, right? (Probably yes).
(2) Is it possible somehow (in Windows XP Pro) to make a drive completely hidden for a XP user - meaning the user cannot access it even using Run > E: or address bar. Neither can any software running under the user profile can access it.
(3) Is it possible (in Windows XP Pro again) to make a device completely unavailable for a XP user and any software running under that user profile (like a Web Cam). But the same device should be able to work under another user profile (Admin). Is this possible somehow? (Using Hardware profiles - may be)
Thanks in advance.
- Bandu.
Bandu is offline
Old 17-08-2008, 12:59 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
tweakui does a good job ..........
... W H O T ...
ax3 is offline
Old 17-08-2008, 01:47 PM   #7 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Yes, the icon is just hidden from my computer, thats all. So typing E: in run box gives you entire access.
Remove the drive letter using Control Panel->Administrative Tools->Computer Management->Disk Management. Restart.
The only thing I can think of is to disable the webcam under device manager, and then give the users limited accounts where they cannot enable it again. When you login to your admin acct, you can enable and use.
dheeraj_kumar is offline
Old 17-08-2008, 01:48 PM   #8 (permalink)
Thanks dheeraj. I'll try that.
Bandu is offline
will too much of disk partitions affect hard-drives??? wraj QnA (read only) 2 12-04-2008 09:36 PM
Please help regarding formatting entire hard disk from bios NiluGeek QnA (read only) 2 15-11-2007 10:17 AM
Hide entire hard drives c: or d: or f: without regedit Batistabomb Tutorials 26 14-10-2007 10:50 AM
to install an os w'out disturbing other hard disk partitions Shasta QnA (read only) 3 26-12-2005 12:12 AM
Deleted partitions in a 80GB hard disk steelcold Hardware Q&A 1 27-11-2005 07:01 PM
