Old 11-05-2005, 07:49 PM   #1 (permalink)
Default CHKDSK over and over
hey ..
what is happenin is that every time is restart it asks to run shkdsk and while checkin indexes it says an unspecified error occured ...
then when my windows passw thing comes (XP w/o welcome screen)it says :
"The file or directory C:\WINDOWS\CSC\d8 is corrupt and unreadable . Please run the ChkDsk utility"
then when i come to windows generally my show desktop button is corrupt and it also corrupts my "my pictures" folder some times ...
it also durin windows keeps givin errors askin me to run chkdsk ....
help !!
CyCo is offline
Old 11-05-2005, 07:56 PM   #2 (permalink)
Run through scandisk from windows it will solve your problem.
\"Let this world be a little better because I came here.
stalin is offline
Old 11-05-2005, 08:01 PM   #3 (permalink)
why need title?
bharathbala2003's Avatar
ok do this
Start->Run
type command and press enter
in the dos window navigate to C:\
type this
C:\fsutil dirty query C:
ull get two results
Drive C: is Dirty
Drive C: is not Dirty
similarly do for all the partitions i.e
C:\fsutil dirty query D: or E: so on
if it says Drive is dirty type this command
C:\chkntfs /D (note there is a space between chkntfs and /D)
then exit and restart this time let the chkdsk run after this it wont keep running again
P.S dont worry even if u have FAT32 jus type that chkntfs /D
the reason could be improper shutdown of the computer.
bharathbala2003 is offline
Old 11-05-2005, 11:39 PM   #4 (permalink)
have tried ur method bharathbala2003
for c it said dirty
for d it said not
for e which is a seperate hdsk it didnt say nethin ...
just gave a blank response
after i did chkntfs /d it just gave the blank thing again ...
AMD Athlon 3500+ 939
Asus A8N-E
HDD: 860GB = 250 x2 + 160 x 2 + 40
Nvidia XFX 7600GT
2GB DDR RAM 400Mhz Transcend
17" LCD Viewsonic
ASUS Sata DVD writer
Logitech MX 518 + Steelpad Qck+
CyCo is offline
Old 11-05-2005, 11:44 PM   #5 (permalink)
swatkat's Avatar
Go to Command Prompt and type chkntfs c: /x and press ENTER. Then restart. Does the Chkdisk runs again?
http://swatrant.blogspot.com/
swatkat is offline
Old 12-05-2005, 02:43 AM   #6 (permalink)
i did a scandisk and it took reall really long like 3hrs ..(it scanned on restart)(i have a 40+120 GB hdsk) ..
i also did the whole thing bharathbala2003 said and it still didnt work ...
this time when i started .. it gave me the same /csc/d* error as well as an error in show desktop.scf and desktop.ini
ill try swatkats method and get back ...
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 12-05-2005, 02:47 AM   #7 (permalink)
when i typed chkntfs c: /x
it just said "the type of the file system is NTFS"
so it shdnt make a diff in restart coz it just gave that o/p right ?
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 14-05-2005, 04:36 AM   #8 (permalink)
pls help some as this is really buggin ..
some times all the errors come and sometimes none at all ...
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 14-05-2005, 09:20 AM   #9 (permalink)
why need title?
well if it comes again and again it cld be a problem with a bad sector.. do this.. disconnect one HDD and connect only one.. then run those commands and restart.. incase chkdsk runs let it.. then restart again if it again runs.. that drive could have the bad sectors.. if not connect both and try and check... make sure the HDD with the OS is connected..
Old 14-05-2005, 11:03 PM   #10 (permalink)
Netjunkie's Avatar
Try chkdsk /f c:
I think that should fix it.
Netjunkie is offline
