I have an assembled Pc Having a 733 Mhz celeron processor,Intel 82810 motherboard
with 128 Mb of Ram, a 20 GB seagate Hard disk and Only windows Xp installed on it.
Q1:I cannot install Windows 98se on my pc. Even though i have formatted my c drive , after compleation
of my installation ,at where it searches for plug & play devices,the machine hangs.I have tried
this 2-3 times but no success. I have changed the RAM and uninstalled the LAN card(not connected to any other comp.)
but nothing seemed to change the intention of my machine.also after reinstalling XP i saw remnant, incompleate installation
folder named "win98SE".What shall i do?
Q2:How can i install Win 98 se if i have only Win XP?
Q3:Are There Any Good PCI GRAPHICs cards available to play modern games.If yes which & where can i get them?
what might be the cost?Are there any sites on the net, Offering them (first hand or second hand)any of them.
Q4:how can i allot RAM to my Graphics card (on board). how can i Tweak it and where and which drivers are the
latest for my Motherboard and graphics C.
Q5:I have a Microtech 15" Multi sync mono CRT colour monitor.Its problem is that the display appears
even after win Xp is loaded . If loading is slow or if i pause the Boot up screen the display after a long time
appears from the the down and swiftlyn goes up as if swinging. Aftersome time this stops
and we get a normal display.Initially the Picture is very dark which after wards brightens
but still the brightness is very less as compared to a normal monitor.I have made the proper
settings for the monitors brightness but still the picture is dark. when i play Quake III the
arena is dark inspite of full in game as well as external brightness settings.And yes , I want to remind
you that the desktop will initially be dark but will never flicker like the windows loading and the boot up screen.
Is it a problem of my graphic card or the CRT?
Q6: The CD-ROM Does not Tray out easily But i have to insert a pin inside the hole near the
eject Button.
Q7:Can i attach a DVD RW at this configuration?
