Old 11-08-2008, 12:10 PM   #1 (permalink)
Default Frequent Disk Defragmentation
Is it a good idea to defragment a partition even if the Anaylser says "No need to defragment"?
Cheers
ajitnavajo is offline
Old 11-08-2008, 12:38 PM   #2 (permalink)
NikhilVerma's Avatar
Default Re: Frequent Disk Defragmentation
Too frequent defragmentation is bad, stresses your hard disk a lot. Probably should use around once every 15 days
NikhilVerma is offline
Old 11-08-2008, 12:48 PM   #3 (permalink)
I haven't ever seen analyser advising me to defragment the disk. But you should regularly do so, say at an interval 15 days or a month depending on how much you use computer.
ThinkFree is offline
Old 11-08-2008, 01:02 PM   #4 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
i wud suggest only to defrag once in a month,for partition storing music files and video dont need defragmentation
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 11-08-2008, 01:14 PM   #5 (permalink)
Defragging partitions depends on your usage... The Windows partition may need to be defragged every 15-30 days... But other partitions may depend on how frequently you use it and what file system is used... Fat32 partitions are more fragmented by nature compared to NTFS partitions... Partitions with more common write operations are likely to be more fragmented...
So, you need to work out by analysing the partitions regularly to figure out how often you need to defrag your various partitions...
Arun
sakumar79 is offline
What does defragmentation do? tamilvendan QnA (read only) 19 08-05-2009 09:40 PM
Defragmentation Nilesh.Ravindran Software Q&A 4 30-04-2007 12:27 PM
Software for Defragmentation.... shyamno Software Q&A 8 18-03-2007 11:29 PM
Disk defragmentation ! ! ! ax3 QnA (read only) 30 09-12-2006 10:27 AM
DeFragmentation Vs Formating HDD Andyiz QnA (read only) 6 15-11-2005 10:28 AM
