Old 09-08-2008, 09:05 PM   #1 (permalink)
Default problem in pc
when i start my pc,
all the processer running but
it does n't start.
my processor is running,hard dics light is on but system does n't start
biswa4fun is offline
Old 09-08-2008, 10:09 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: problem in pc
did u switch ON the monitor adn looked for any error msgs ??? try pressing the F8 adn select LAST KNOWN GOOD CONFIGURATION that WORKED...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 10-08-2008, 07:32 AM   #3 (permalink)
M3TAL H3AD M3
skippednote's Avatar
If there is no display at all then your ram may be loose or your motherboard or smps might have gone bad
I spit Rainbows.
skippednote is offline
Old 10-08-2008, 10:07 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Is it brand new system?? or a old computer??
ravi_9793 is offline
Old 10-08-2008, 11:39 AM   #5 (permalink)
its the smps problem that causes NOTHING to be displayed on the monitor..
btw, its a hard thing to find out wat component has gone bad, and u'll hv to check it part by part on a separatre system ofcourse, maybe on ur friend's PC.... try ur RAM(s) then ur SMPS..
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 26-08-2008, 02:13 PM   #6 (permalink)
Post Re: problem in pc
when i shut down my system it takes long time to shut down
Old 26-08-2008, 02:17 PM   #7 (permalink)
in ur 1st post u wrote this:
when i start my pc,
it does n't start.
is that solved???
well, if ur PC takes alot of time to shutdown (im considering that u can see things on ur screen), so plz try and defrag ur HDD...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 27-08-2008, 06:50 PM   #8 (permalink)
Wink Re: problem in pc
Hi,
First Chek your Ram if your using single ram try to use at anotherslot or Two rams use ram to chek that and chek that another ram with Alternative ram Slots...
if above that options not working chek your SMPS..
Reg
mahendran
teamonesolutions is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
