he is interested in a printout which should be customizable with respect to fonts,ssize and colour in print preview.... how to proceed as in VB usually theres only one default size, font we have to select.... is this possible? if yes,, how?
thanks
ps- i m attaching the screenshot of that software and print preview page.
There is an object called printer. Go to coding area and type printer. and you will see the available options like copies, font, fontbold, fontitalic, fontsize, fontname, forecolor, etc. Set these to get the required effect.
Here's my 2 bits. VB is not so naive. There are more than one way of doing the same thing. What you do is have predefined settings with each variable declared as Printer.
For example you can have something like this in a calendar printing software.
Dim DeskCal as Printer, PocketCal as Printer
Now setup properties of DeskCal with some default best suited for printing desktop calendar and so on for PocketCal. Hope this is useful
