Old 09-08-2008, 11:06 AM   #1 (permalink)
Default shut down problem........
hello friends,
I m using windows xp pro. My modem burnt due to lightning and it caused some sparking. . After that when I shut down my pc, it keeps on displaying the message that windows is shutting down but does not shuts down and I have to turn off pc by pressing power button. keyboard and mouse are turned off during this process. After this problem, my pc has become very slow and IE hangs very frequently. Can anybody suggest a solution........
Regards,
peyoush thakur
peyoush_thakur is offline
Old 09-08-2008, 11:12 AM   #2 (permalink)
slugger's Avatar
Default Re: shut down problem........
looks morelike a case of file corruption to me
repair/reinastall the OS and install a good paid AV [KAV, NOD32]
slugger is offline
Old 09-08-2008, 12:53 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
check for bad sector in hard disk for all drives.
ravi_9793 is offline
Old 11-08-2008, 09:51 PM   #4 (permalink)
I have reinstalled the OS but the problem remains same.
Old 12-08-2008, 02:05 AM   #5 (permalink)
Lets Do It!
amrawtanshx's Avatar
Must not be file corruption case.
Maybe some part of the motherboard may have got burnt too.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 12-08-2008, 06:30 PM   #6 (permalink)
The Black Waltz
this may b due to some damaged components. call sumone who knows and ask him to open the cabinet and check all parts. if any of the parts are damaged, then you'll probably have to get them replaced.
Cool Joe is offline
Old 12-08-2008, 08:57 PM   #7 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
lightning ?? lightning strike??
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Shut down problem Arun Kumar QnA (read only) 2 29-12-2007 06:02 PM
hav problem related to shut down Vishakh Software Q&A 3 20-08-2006 07:18 PM
Windows 98 SE shut down problem! Johnny_Bravo Software Q&A 2 17-06-2006 11:56 PM
_khAttAm_'s shut UP and shut DOWN tool!! [updated 6/17/05] khattam_ QnA (read only) 12 19-06-2005 05:57 AM
shut down problem help!! sniper43228 QnA (read only) 2 02-01-2005 01:22 PM
