Old 10-05-2005, 09:05 PM   #1 (permalink)
Default best converter frm mp3 to all types
hi,
hey i wanted to convert some mp3 to diff formats.but to my dismay,this spelled a lot of troubles.i lost some .vxd etc files somehow.dont know how.i had to format and reinstall.my mouse,display,sound drivers stopped working properly for a while.man it was a hectic week(previous).so what i wanted from u all is a list of safe and free softwares which can convert mp3s to any format possible.plz suggest names which u all have used in recent future.i was using mp3 to all software(dnt remember the companys name).this i got after googling....
do let me know...
tx
krisjr is offline
Old 10-05-2005, 09:27 PM   #2 (permalink)
swatkat's Avatar
dBPowerAmp is one of the best freeware available for conversion. Also, install these codecs with which you can convert to more formats.
http://swatrant.blogspot.com/
swatkat is offline
Old 10-05-2005, 11:44 PM   #3 (permalink)
Ashis's Avatar
All to MP3 & MP3 to All
But Its not free !!! (30 Days i guess)
I know U can do a lot in 30 Days
Audio Conversion Wizard
If U like it post ur experience !!!
Ashis is offline
Old 11-05-2005, 12:16 AM   #4 (permalink)
I second swatkat, nothing can beat dBPowerAmp. Its Free too.
Hard work never killed anybody..........But why take the RISK
indrajit is offline
Old 11-05-2005, 02:55 AM   #5 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
A software is bundled with NERO Suite.. .. it is Nero Wave Editor, the convertion is good. i also use dBPowerAmp for rippin.
rollcage is offline
Old 11-05-2005, 03:16 AM   #6 (permalink)
Thanks a ton swat.
As the site says, dBpowerAMP will convert .mp3 to any media provided, the codec is installed.
Will surely download and will try converting. I like .rm next to .mp3 as the quality rocks(Also B'coz the they are the mostly available media on net)
Yes man alot can be done in 30 days. Make the best out of Shareware.
RajŪ Anyone else is not me...!!!
rajas is offline
Old 12-05-2005, 03:38 PM   #7 (permalink)
Just Do It
Charley's Avatar
DBpoweramp again, the best software for converting
Charley is offline
Old 13-05-2005, 12:59 AM   #8 (permalink)
hey swatkat,have u used this monkeys audio format ever.let me know plz.will it play in Hi-FI systems
krisjr is offline
Old 13-05-2005, 01:33 AM   #9 (permalink)
swatkat's Avatar
Hi,
i have not tried Monkey Audio, and it is not supported by Hi-fi systems.
swatkat is offline
Old 13-05-2005, 06:53 AM   #10 (permalink)
Tux
Posts: n/a
Whenever I use dBPowerAmp to convert a mp3 to other format, the output contains noises of scracthes. Why so. Original doesn't have any disturbance
Old 13-05-2005, 11:53 AM   #11 (permalink)
Default mp3 to all converter
"free cd extrcter" is also a good format converter
himanshu parashar is offline
Old 13-05-2005, 11:57 AM   #12 (permalink)
it can be found in DIGIT Mindware CD
Old 13-05-2005, 12:13 PM   #13 (permalink)
Just Do It
Charley's Avatar
What are you trying to mean by "noises of scratches" ?
Charley is offline
Old 19-05-2005, 06:24 PM   #14 (permalink)
Gaurav's Avatar
The MP3 codec of dbpoweramp is not free. what are you doing to convert your files.
Gaurav is offline
Old 19-05-2005, 11:07 PM   #15 (permalink)
hey i have also heard tat from frens..ters some kinda sound,not sure wether its like scratching or wat,any suggestions swat.hav u experienced such things.
krisjr is offline
Old 20-05-2005, 01:16 PM   #16 (permalink)
Just Do It
Charley's Avatar
@GAURAV, locate the codec link above and u can find ur requirement. 8)
Charley is offline
