Old 10-05-2005, 02:32 PM   #1 (permalink)
Default DUMeter Issue
Hi Folks,
I've just installed DUMeter for the first time, and there's something terribly wrong with either DUMeter of my System.
The Graphs shows a constant use of 27+kb/sec of download data and it doesnt even stop for a second even tough I close everything, even my msn messenger.
Is that normal or there's something killing my bandwidth?
Any help greatly appreciated. Thanks.
Hexus is offline
Old 10-05-2005, 02:57 PM   #2 (permalink)
mekalodu
iinfi's Avatar
i have used it b4...
i think there is an option of selecting "dial up only" ...
i think u sud enable that ....
otherwise it detects transfer of data inside ur HDD ...
i m not sure abt this answer ...
mekalodu
iinfi is offline
Old 10-05-2005, 03:11 PM   #3 (permalink)
But I'm connected through a LAN Card, and if I select Dial-up, it shows no activity at all, stays at '0'. And if my LAN Card is selected, it works the same way as I mentioned above.
I believe, there's something killing my bandwidth terribly, what could it be?
Hexus is offline
Old 10-05-2005, 03:28 PM   #4 (permalink)
harmax's Avatar
no worry till june 30 if its dataone
harmax is offline
Old 10-05-2005, 04:26 PM   #5 (permalink)
harmax,
I didn't quite follow you. What did you mean exactly?
Hexus is offline
Old 10-05-2005, 05:09 PM   #6 (permalink)
chinmay's Avatar
Hexus do u have an antivirus installed?...it may b quite possible if that anyone else connected on the same lan network can hack ur system..if its some famous conn. like sify or airtel then its probably not possible ..but its quite possible in a local cable net wallah...may b a trojan is hackin ur system or somethin like that...i dun wanna scre u but then u shud install a good firewall and antivirus software....secondly plz post ur hijack log file so that swatkat and others(includin me) can check if there is any serious problem..
I Blog at - http://www.chinmayspeaks.com
chinmay is offline
Old 10-05-2005, 06:44 PM   #7 (permalink)
Hi Chinmay,
Thanks for the quick response. Yes, I just Full formatted my system making my C Drive and had Norton Systemworks 2005 - with Norton Antivirus 2005 - installed.
Norton seemed to be acting up on, so I successfully uninstalled it and Installed 'Avast Professional Edition'.
My Internet is of a local cable guy, they colocate in PrimeNet Datacenter. Connection is stable usually, but it isnt too good since last few days. I connect through a Lan Card as mentioned earlier.
Following is my HijackThis Log:
[Removed]
Any help greatly appreciated. Thanks heaps.
Hexus is offline
Old 10-05-2005, 07:06 PM   #8 (permalink)
I had'nt used HijackThis for a long time, I firgured it out myself, but there nothing too suspicious.
There's something else killing my bandwidth!
Hexus is offline
