We'll I desperately need some tutorial for it
I've tried replacing it several times using all the methods I can & even when The file is replaced with mine the screen doesn't show up the bootscreen intended to be there
If you are on XP and want to change the boot screen, use BootSkins.
^^ As I've told you that i know how to create a bootscreen but replacing isn't working
I've even replaced the file & checked that if the replaced file is actually the 1 but it still isn't working
Try replacing the file with this software. Its actually difficult to to answer why it is not happening if you have done stuff as mentioned in the above post.
