Old 09-05-2005, 08:51 PM   #1 (permalink)
rajat22's Avatar
Default another great application
Application Mover
This is another great application. If any programme is installed in a drive from
which you want to remove to another drive without uninstalling, you need this.
This will move everything of that programme including registry value resulting
in as if it was installed in that drive. Only drawback is it is a shareware.
Application Mover is a tool that relocates installed programs from one path to
another on your hard disk. Application Mover takes files found in the path
specified in the 'Current Path' field (see below) and moves them to the 'New
Path' path. Application Mover scans the windows registry for references to
files located in the 'Current' field and changes those references to the 'New'
path. Application Mover also scans all windows shortcuts in the Start Menu
and adjusts path references to the new program location. Finally, *.ini and
Install.log files present in the original program path are checked for strings
matching the old path location. If found, these strings are changed to the new
location. Confirmation dialogs are available if you enable the 'Confirm
changes' checkbox (see below). If a file is 'busy' and cannot be changed to
the new location, a reboot prompt is offered. Pending changes are then
completed after the reboot.
Download it
http://www.funduc.com/ftp/apmvshr.zip
rajat22 is offline
Old 09-05-2005, 09:22 PM   #2 (permalink)
will try...thanks fpr sharing
atool is offline
Old 09-05-2005, 10:37 PM   #3 (permalink)
I suppose there is something like this in System Mechanic too.
SatishSays.com
twitter.com/satishsays
devilhead_satish is offline
Old 10-05-2005, 01:25 AM   #4 (permalink)
no ... nothing like this is there in sys mech.
grinning_devil is offline
Old 10-05-2005, 02:13 PM   #5 (permalink)
whoopy_whale's Avatar
Hmm...There is Application Relocater tool in System Mechanic Professional edition.It moves an application installed in one place on your system to another location on your system, such as a new drive or directory.
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 10-05-2005, 04:57 PM   #6 (permalink)
I've used the tool in sysmech, it's good. The good thing about sysmech is that it has a lot of tools integrated into one software.
imcool is offline
Old 11-05-2005, 09:54 AM   #7 (permalink)
sujithtom's Avatar
Y ai also use System Mechanic. Greate tool. But when i tried to move Spiderman 2 game I waited for 2 hours yet the apliaction wan't moved even 50%. So i had to stop it
http://geeksbay.monzilla.info - My Tech Blog :)
sujithtom is offline
- by tkin
