Re: RAR parts CRC failed
make sure u have all the downloaded parts 1 to 10 in the same folder.
then extract part 1... it will automatically join all the parts and give u a complte file.
if this doesnt work,then u must have missed some part. make sure u have all the parts.
even then the problem persists then u can do this:
click on the extract button and it will open up a window. see for the checkbox "keep broken file" somewhere at the bottom left side. CHECK it and then try to extract...
TechExplorer.in
