Old 09-05-2005, 07:21 PM   #1 (permalink)
pradipudhaya's Avatar
Default Power Failure, What should I do?
Hello people, please help me. Well, what should I do if the computer turns off after a power failure?? After restarting, wat are the steps to be taken? Thank you.
pradipudhaya is offline
Old 09-05-2005, 08:56 PM   #2 (permalink)
Most probably nothing. If you were doing something important and hadn't saved your progress, you will lose the data. Windows might ask you to run ScanDisk or something as it wasn't shut down properly. But most of the time, nothing happens. I have had a few such cases and when the power returned, I just switched it back on and had no trouble whatsoever.
Nemesis is offline
Old 09-05-2005, 08:58 PM   #3 (permalink)
Thanks a lot
Old 09-05-2005, 10:41 PM   #4 (permalink)
Firstly let me say its not good for your hard ware when your system goes down abruptly due to a power failure. Solution Get a UPS. any way if it does happen then do the folloing:
If working in windows i would recommend a scan disk (it is done automatically) to be done on all drives and if working in ms office recover your document and physically detete the temp files that are left behind.
**** happens
pradeep_chauhan is offline
Old 09-05-2005, 11:02 PM   #5 (permalink)
club_pranay's Avatar
it's not much of a problem most of the time but not when...
1. Flashing a BIOS
2. performing a Low level Format
3. booting to a OS
4. defragmenting
etc
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 09-05-2005, 11:45 PM   #6 (permalink)
format????data loss!!!!wht r u talking...decent solution..get an online ups providing backup time 4 shutdown
magnet is offline
Old 10-05-2005, 10:20 AM   #7 (permalink)
Get an APC or a Numeric or a WEP UPS or there are loads of other UPSes that will give you around 20 mins of backup time. BTW Office XP onwards there is an autosave feature. It'll start of right where the Mr. Electricity decided to take a break. Also you can smack up those stupid and corrupt MSEB officials as an extreme measure
SatishSays.com
twitter.com/satishsays
devilhead_satish is offline
Old 10-05-2005, 11:28 AM   #8 (permalink)
rohanbee's Avatar
UPS.............i never owned one for so many years. Now that i do im always looking for the best one and replacing the old one. A lot fo things get busted in india due to faulty power loads and spikes so be very very carefull.
Also, the prices on the UPS's have crashed quite a bit and a good branded one could be bought for around 3000 or so.
Quote by Garfield'
rohanbee is offline
Old 10-05-2005, 04:53 PM   #9 (permalink)
Default hi
microtek 800va costs abt 2350
akshayt is offline
Old 10-05-2005, 07:54 PM   #10 (permalink)
tx
Old 13-05-2005, 08:34 PM   #11 (permalink)
Don't skip "chkdsk" in XP and Scandisk in 98.
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
Old 16-05-2005, 09:24 AM   #12 (permalink)
MVP in VC++
Default Re: Power Failure, What should I do?
Just allow to scan...........buddy.....
cvvikram is offline
- by tkin
