Old 01-08-2008, 02:55 PM   #1 (permalink)
The Devil
blackpearl's Avatar
Question Domain transfer doubts
I want to transfer my domain from yahoo to godaddy. Now I have heard that a domain transfer can take upto sevearl days and even weeks to complete. Will my site remain unavailable during this period? I have heard that the site is available while the transfer process is going on. Only after the transfer is completed and the nameserver changed, that the site goes offline.
Is that true? Will the site go offline during the entire transfer period or only for the time taken by the nameserver at the new registrar to update?
blackpearl is offline
Old 01-08-2008, 03:08 PM   #2 (permalink)
eWebGuru
ahref's Avatar
Default Re: Domain transfer doubts
During domain transfer you cant change nameserver, site doesnt go down, if you are also shifting hosting, you should first transfer hosting change nameserver then shift domain.
If you are not changing hosting, then site will not go down.
Windows and linux hosting at http://www.ewebguru.com
Get $50 per blog post PM me for details.
ahref is offline
Old 01-08-2008, 03:36 PM   #3 (permalink)
The Devil
blackpearl's Avatar
No I'm not changing hosting, just changing registrar. The nameserver will remain intact on yahoo and I will initiate a domain transfer to godaddy. After the domain gets transfered to godaddy, I have to set the nameserver, isn't not?
Also the nameserver on godaddy will take some time to update. During that time the site should be unavailable, or will visitors be redirected correctly to my site from the old DNS records?
Please explain how my site will NOT go down.
Thanks
Old 01-08-2008, 04:14 PM   #4 (permalink)
eWebGuru
ahref's Avatar
Your site will not go down, after transfer your nameserver will remain same. Since you are not changing nameserver your site will remain available always.
You need not to update nameserver at godaddy panel, as domain will be transfered with exisiting nameserver settings,
ahref is offline
Old 01-08-2008, 08:15 PM   #5 (permalink)
The Devil
blackpearl's Avatar
Thanks ahref. I was worried about my site going offline.
Old 01-08-2008, 08:21 PM   #6 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
+1 with Ahref
Your site will be available all the time so no worries with transfer Go ahead
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 04-08-2008, 10:55 AM   #7 (permalink)
The Devil
blackpearl's Avatar
Some problem. I just noticed that on my yahoo control panel, the name servers are set as "yns1.yahoo.com". To map my website to the address, I used CNAME records. Now what do I do to the nameserver when I transfer to godaddy? should I make it the same as the CNAME records?
Old 04-08-2008, 02:20 PM   #8 (permalink)
TechTin.com
ravi_9793's Avatar
where is your website hosted??
ravi_9793 is offline
Old 04-08-2008, 03:23 PM   #9 (permalink)
The Devil
blackpearl's Avatar
My site is on blogger.
Nameservers are yns1.yahoo.com and yns2.yahoo.com
CNAME record is set to ghs.google.com, which is for blogger.
Old 04-08-2008, 03:57 PM   #10 (permalink)
Host4Cheap.org
Change the Nameservers to EveryDNS
ns1.everydns.net,
ns2.everydns.net,
ns3.everydns.net,
and ns4.everydns.net
Then Read this http://help.blogger.com/bin/answer.p...58317#everydns
At the moment you are using Yahoo DNS Management. I am not sure if Godaddy provides DNS Management for FREE. Your best bet is to use FREE EVERYDNS
Old 04-08-2008, 04:22 PM   #11 (permalink)
TechTin.com
ravi_9793's Avatar
As Sukhdeep Singh said, you can use everydns.net
Else, buy DNS service also from Godaddy, and change nameserver and configure again at Godaddy domain control panel.
Old 04-08-2008, 04:30 PM   #12 (permalink)
The Devil
blackpearl's Avatar
I think godaddy gives dns service for free, called offsite dns. See this
http://help.godaddy.com/article/4041
I don't want to use everydns. Now what should I do? Should I change the nameservers at yahoo to godaddy as shown in the link I gave, or just go forward with the transfer. What will happen then?
I 'm confused.
Here is godaddy's guide to transfer domain
https://products.secureserver.net/gu...main_yahoo.pdf
I think I should just follow it. But my site would go offline isn't so?
Old 04-08-2008, 05:17 PM   #13 (permalink)
Host4Cheap.org
I
Yes, do this AFAIK as i can understand, why will be fine.
BUT why not use EveryDNS now and when u face probs, move back to Godaddy ?
Old 04-08-2008, 05:35 PM   #14 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
godaddy has issues, esp concerning laws on parked domains. it calls everyone with a vaguely familiar domain name squatters, or so the story goes. also, it places ads on your domain while not in use. atleast this is what my online research indicates.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 04-08-2008, 06:25 PM   #15 (permalink)
Host4Cheap.org
Not Exactly, It is World Biggest Registrar for no reason
Old 04-08-2008, 06:57 PM   #16 (permalink)
The Devil
blackpearl's Avatar
I think the best way will be to proceed as described in the PDF file (found at godaddy). If I try to act smart and do something different it will probably go wrong.
From what I understand, the namservers will be automatically updated at godaddy once the transfer is complete. What I want to know now is: Will the CNAME records be automatically updated at the new registrar?
If yes, then I have nothing to worry. If no, I will have few hours of downtime as the records propagates.
Please answer the BOLD question
Old 04-08-2008, 09:39 PM   #17 (permalink)
TechTin.com
ravi_9793's Avatar
You must contact Godaddy support team for this. But I am scared that it will not be done automatically.
Old 04-08-2008, 10:19 PM   #18 (permalink)
eWebGuru
ahref's Avatar
Since you are using yahoo service for managing DNS entries, once you transfer your domain to godaddy, probably you will not be able to use yahoo service for DNS, hence your cname record will not work.
If your manage DNS service works at yahoo even after transfer of domain to godaddy then cname record will work.
If you want to use godaddy service for managing DNS then you need to change your nameserver to godaddy and also have to create cname record again, cname record definately will not be updated automatically.
ahref is offline
Old 05-08-2008, 11:37 AM   #19 (permalink)
Host4Cheap.org
No offence, if you are going with Godaddy, it means you find relaible, trustworthy and they would help you in all problems.
All the Questions should be best answerable by Godaddy Support since it has been years that i have been with Godaddy
Old 05-08-2008, 03:48 PM   #20 (permalink)
The Devil
blackpearl's Avatar
Mailed godaddy and awaiting their reply.
I think you guys are right. CNAME records won't update. I have to do it manually.
Got godaddy's reply, and I have figured it out how to avoid downtime.
Godaddy said that I can choose to keep the nameserver when I transfer my domain. Again, Yahoo's help files say that I have to cancel my account manually once the transfer is complete. Yahoo will NOT cancel my account automatically. Now I know what to do.
1. I will transfer my domain to godaddy and keep the namerserver as yahoo.
2. After the domain is transfered to godaddy, the DNS management will still be with yahoo. So no downtime.
3. I will change the namersevr at godaddy to use godaddy's DNS management BUT I will NOT canecl my yahoo account.
4. During the time required for godaddy's nameserver to update, my site will still be accessible since I have not canceld yahoo's DNS
5. After the new namersver becomes active only then will I cancel yahoo's account.
Result = 0 downtime (hopefully)
So what do you say?
domain transfer realmmahesh QnA (read only) 5 16-11-2007 12:00 PM
Website to accept domain name payments and send domain names Charley QnA (read only) 3 06-10-2007 06:45 PM
Question abt Domain transfer Sparsh007 QnA (read only) 25 22-09-2007 06:27 PM
Domain Transfer The Unknown QnA (read only) 1 26-08-2007 06:27 PM
Domain Transfer - Help please ranjithbajpe QnA (read only) 2 17-05-2006 02:30 PM
- by tkin
