i m a member of this site.
my problem is that everytime i login and start to browse here i m logged of automatically after some time.i have to again login n start.
the same sort of problem happens again n i have to again login.
can anybody suggest the solution?
While you are going to logon, dont forget to check the checkbox: Remember Me?
This will keep you loged on everytime till you will not click on log off.
thanks for da sleek solution.
still me confused,since i use cyber net,doesn't doing that keeps my password saved or remembered by that computer?
waiting for yr reply.
