Old 31-07-2008, 07:19 PM   #1 (permalink)
Default Apc Ups
my apc (back-up es 650) UPS makes beep sound at certain intervels when power goes off.is there anyway i can turn the beep sound off?
temperworld is offline
Old 31-07-2008, 07:39 PM   #2 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Default Re: Apc Ups
sorry no chance
I spit Rainbows.
skippednote is offline
Old 31-07-2008, 08:03 PM   #3 (permalink)
hmmmmmmmmmmmmm's Avatar
Default Re: Apc Ups
haha cant man get urself APC - 800
u can Mute the Alarm...lol..
Sellin Rapidshare Account 30 Days Validity for 6 $ PM ME
hmmmmmmmmmmmmm is offline
Old 31-07-2008, 10:28 PM   #4 (permalink)
Default Re: Apc Ups
The beeper is intended to warn you that you are running on battery power. If it bothers you that much, you can open the UPS and disconnect the buzzer, or have a techie do it for you. But it may void the warranty if you have any left.
pimpom is offline
Old 31-07-2008, 10:30 PM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Apc Ups
Cut The Hard Line
desiibond is offline
Old 01-08-2008, 02:27 PM   #6 (permalink)
Default Re: Apc Ups
Originally Posted by desiibond View Post
Cut The Hard Line
but u stand to lose warranty
spindoc is offline
Old 01-08-2008, 02:47 PM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Apc Ups
^^ ah. looks like you didn't get it. It's a dialogue from the movie "Matrix"
Just live with it. It's an indicator.
Old 02-08-2008, 11:20 PM   #8 (permalink)
Default Re: Apc Ups
i turned the beep sound off. there is software called "APC PowerChute Personal Edition" that comes with APC ups , in that software u can configure to turn off the alarm sound.
Old 02-08-2008, 11:23 PM   #9 (permalink)
 Macboy
goobimama's Avatar
Default Re: Apc Ups
Well you could also just about take your UPS to any electrician, make him open it up and remove the beeper! I'll be doing that one of these days. Screw the warranty, this is my sanity at stake.
I'm like a bird... :)
goobimama is offline
Old 03-08-2008, 12:14 AM   #10 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Default Re: Apc Ups
Thats the easiest and best way to do it dude!
also you will get additional features with it(i use automatic shutdown and switch on feature).. but dont forget to plugin the usb cable came with the ups to the computer
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 03-08-2008, 09:36 AM   #11 (permalink)
Default Re: Apc Ups
thank u for the info
- by tkin
