1) I tried installing Microsoft Windows XP SP2 on to my PC running on Windows XP Professional, but it gives me a warning that setup cannot continue because the key used gor Windows XP is invalid and to resolve this problem i should visit
www.howtotell.com.
How can i get through this problem.I really need to install SP2 as most of the softwares now days need SP2 as the basic requirement.
2) Secondly i have a 160 GB HDD having the following partitions:
c:\ 19.5 GB
d:\ 29.2 GB
e:\ 48.8 GB
f:\ 51.3 GB
I have approx. 23.5 GB space free in D partition and rest is the used space. I want to create an unallocated space out of this 23.5 GB partition and want the size of that space to be approx 15 GB. Now i want to do this without wiping of the data present on D:\ and without using commercial softwares such as Partition Magic. Does any one knows a software that can run in Windows or DOS that can solve this problem.I've consulted a old Handbook for the 30 min expert distributed by DIGIT a long time ago.It states that i can use BootIT NG in such cases.Will it be able to do the work?
Thanks
