Old 30-07-2008, 05:40 PM   #1 (permalink)
Default NEWFOLDER.exe
ystrday i plugged in a pendrive and that had Newfolder.exe file......I copied some photos and then after restarting the CPU i am recieving the problem of folders opening in another window....and also i cant see the hidden folders(eventhough i tried in the folders option)....pls help guys.....( i am new to computer world)
kula is offline
Old 30-07-2008, 05:50 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: NEWFOLDER.exe
One of most common and sucky virus out theere
Try this if it helps
http://www.mediafire.com/?m4wxj1znmto
Try installing a Good Antivirus to keep safe
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 31-07-2008, 08:46 AM   #3 (permalink)
raksrules's Avatar
Its a virus. I had in my machine too. I replicated all the folders and made them an executable, so that songs had a copy named songs.exe. I have avast installed at my home with latest signatures and it got detected and removed it
raksrules is offline
Old 31-07-2008, 03:19 PM   #4 (permalink)
D@rekills4's Avatar
Default Virus
No giving illegal stuff around here. See you in a few days. - goobi
D@rekills4 is offline
Old 31-07-2008, 06:17 PM   #5 (permalink)
Thumbs up Re: Virus
Originally Posted by D@rekills4 View Post
snipped
Hai thanks man
kula is offline
Old 31-07-2008, 06:20 PM   #6 (permalink)
M3TAL H3AD M3
skippednote's Avatar
snipped
Report cracks and hacking
I spit Rainbows.
skippednote is offline
Old 31-07-2008, 10:51 PM   #7 (permalink)
Tech'ing life seriously!!
sude's Avatar
try this link to remove newfolder.exe
http://www.spywareremove.com/removenewfolderexe.html
reported for supporting piracy...
SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 31-07-2008, 11:53 PM   #8 (permalink)
just scan your computer with av and antispyware
abhijangda is offline
Old 01-08-2008, 04:23 AM   #9 (permalink)
DigitDonz's Avatar
I too had the same problem and the same virus a couple of months back, I scanned using Norton 2008 AV and was detected and removed but I am sure any AV with latest signatures will do the treatment...
;) Join the new blogging arena on the internet Visit http://www.softwaredonz.co.nr
DigitDonz is offline
Old 01-08-2008, 06:54 AM   #10 (permalink)
hsr
Senior Owner
hsr's Avatar
it's just a phreakin virus. usually comes with p()rn . to remove it just do a system restore to a point just b4 you plugged ur "p-drive" as you call it. my friends had the same problem. if you use anti-virus, only the virus will be removed but the hidden file protection will be still there. so i say, do a system restore and then remove the virus. provided you have the latest update and a good antivirus like avast mcafee or kaspersky.
Read Rules > FAQs > Stickies before posting a new thread. PM me anytime for an issue, and I'll be idle on irc too.
My dream rig.
ლ(ಠ_ಠ)ლ Webchat for Digit.
hsr is offline
Old 04-10-2008, 12:53 PM   #11 (permalink)
first create a folder, then rename as your name.
open it.If there have a folder as your name,your com infected by ssvcchost virus or by their family,Friend if true your pc r not lucky.But new avg 8 can help u to remove this virus
Nir ur friend
nirjhar is offline
Old 04-10-2008, 01:35 PM   #12 (permalink)
TheSaint
NucleusKore's Avatar
Best way to clean this virus is to use Avira run from UBCD4WIN, with the options set to automatically repair (primary) or delete (secondary). Works like a charm.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 04-10-2008, 01:42 PM   #13 (permalink)
M3TAL H3AD M3
get a online virus check up and post HiJack log
I spit Rainbows.
Old 04-10-2008, 04:59 PM   #14 (permalink)
paroh's Avatar
install USB.Disk.Security. It will help in preventing virus that are spread through USB drives
paroh is offline
Old 04-10-2008, 05:28 PM   #15 (permalink)
hsr
Senior Owner
hsr's Avatar
actually a prog called driveprotect (which is also avail for vist@) is a bloody got damn rootkit and it fks realtime !
My dream rig.
hsr is offline
Old 04-10-2008, 05:32 PM   #16 (permalink)
Fullbring
Zangetsu's Avatar
+1
must be removed even if ur antivirus DB is some days old...
Zangetsu is offline
My pen drive got newfolder.exe virus sganesh Software Q&A 8 07-04-2008 06:48 PM
my vista got stuck with newfolder.exe sganesh Software Q&A 1 22-03-2008 08:06 PM
- by tkin
