The same as between chalk and cheese DVD has 4.7 GB capacity while CD has 700 MB. A DVD can also be dual-layered, while there is no such thing as a dual-layered CD.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
well dvd gives u space of abt 9 times ur general cd, in appearnce and description u wont be able to spot the diff at first glance becos both look nealr same and weigh nealr the same as mentioned in above posts
Attack life, it\'s going to kill you anyway.
Now Then....Theres is actually a physical difference not much but u can.....Cd are more more reflective in light ( Duh means they reflect more light )than DVD...Dono Coz but may be Coz Dvd has a close nit layer Technology to accomodate Data and Cd's are more Accomodative...of space and hence a reflection ( Yes REmember one can see how much Mb Approz a cd is written just by checking the back side ....we can see a clear distinctive pattern )
Yep
svenkat83
We know they are backward compatible.
N
walking-techie ya sayin
'u wont be able to spot the diff at first glance becos both look nealr same and weigh nealr the same '
OK.Fine but....
What is the difference you spotted on your second glance?
Please enlighten us...
