Old 09-05-2005, 12:44 AM   #1 (permalink)
Default DVD or DIVX or MPEG
guys, which format is the best in terms of visual quality like DVDs are way better than VCDs.
medigit is offline
Old 09-05-2005, 12:45 AM   #2 (permalink)
hmmm... it must be .avi
Simply great! compressed & excellent sound & video quality!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 09-05-2005, 03:30 AM   #3 (permalink)
Among DVD, DIVX and MPEG...DVD is the BEST one in quality but least one in quantity(size).
DVD is great quality(picture and sound) but takes heavy size.
DivX is good quality(picture&sound) least size just equal to mpeg-1
MPEG actually having 3 versions in video category they are mpeg-1 mpeg-2 and mpeg-4.
I think in your view you are asking about VCD(MPEG-1).... which is least quality among DVD Divx...
I will prefer divx because of good quality as well as least size.
Divx players(not softwares physical players) also available...so this one may be the next video generaion in common world. At present in IT world Divx is popular.
Check Below details...take decision which one is better:
TYPE------------------Resolution------------1 Minute file size
DVD(MPEG-2codec)------720 X 576---------------near to 50 MB
DivX((MPEG-4)-----------640 x 480 or lower-----1 to 10 MB
VCD(MPEG-1)-------------352 X 288-----------------10 MB
ramakrishna.nalla is offline
Old 09-05-2005, 03:40 AM   #4 (permalink)
sunnydiv
Posts: n/a
avi eh
ne ways, based on current requirements ur best bet is XVID
i get near dvd quality results @ 756 kbps
if you compare quality with pirated stuff, then divx/xvid is ur best bet
as of orignals, DVD is good, but you can always encode divx with better bitrates
Old 09-05-2005, 07:37 AM   #5 (permalink)
so ....... v here 2 compare dvdz n vcdz
unless u have an oil well in the middle-east n thus have enough space 2 rip n store each dvd that comes ur way or 4 that matter ( remember u have the moolah ) buy each n every 1 of them u like at planet M , i suggest u go with divx/xvid .
u can always alter things 2 ur liking . so as sunnydiv said , alter the bitrate 2 meet ur req. e.g. default audio ( mp3 ) encoding bitrate in Dr Divx is 64 kbps , u can bring it up2 128 ( the normal mp3 encoding value ) . but as u shud no , file size is proportional 2 the quality desired
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
mamba is offline
Old 09-05-2005, 08:32 AM   #6 (permalink)
chinmay's Avatar
why d u need an oil well dude....jus go to pallika n buy copies of original dvds for 100 bucks....nad 160 gb hdds are also pretty cheap.....
btw i'll go 4 divx...its a correct proportion between size n quality...
I Blog at - http://www.chinmayspeaks.com
chinmay is offline
Old 09-05-2005, 11:38 PM   #7 (permalink)
was referring 2 storing those dvdz in the original format , not converting them 2 divx or something 4 the ' fear ' of loss of some quality
most dvd moviez r bigger than 6GB , n that 160 GB hdd wont hold on 4 long . or even make that 2 of them if some1 is as big a movie buff as my frnd ( has bout 300 movies , scattered here n there )
mamba is offline
Old 10-05-2005, 02:12 AM   #8 (permalink)
ofcourse .avi directly corresponds to DIVX .. isn't it ???
Old 10-05-2005, 09:15 AM   #9 (permalink)
club_pranay's Avatar
if space is the probles then .avi or DivX
if not then surely .vob
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 10-05-2005, 09:19 AM   #10 (permalink)
guys I tell u that dvd is the best among quality. Exellent sound and video. Divx is the next. I don't have third!
A student must not fail to become a looser, and when a student fails, he will become a fighter....
Santosh Halemani
Santosh Halemani is offline
Old 10-05-2005, 10:29 PM   #11 (permalink)
Thor's Avatar
I recently Installed A1 DVD Ripper, and DivX Pro 5.2.1 . While Encoding a movie [XXX2] I set the setting to Max Quality and Slow Speed. Damn. The encoding was being done at 2fps !! Estimated time : 19 hrs.
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 11-05-2005, 02:30 AM   #12 (permalink)
yes! its damn! sloooooooooooooooooowwwwwwwwwwwwww!
Old 11-05-2005, 04:47 AM   #13 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
read this guys,
http://www.thinkdigit.com/forum/viewtopic.php?t=11772
rollcage is offline
Old 11-05-2005, 01:02 PM   #14 (permalink)
Just Do It
Charley's Avatar
DVD rocks, the quality is better than the others.
Charley is offline
Old 11-05-2005, 08:15 PM   #15 (permalink)
MPEG4 is quite good too. I tried encoding some tv captures to that format and was quite pleased with the results. File size is small and picture quality is good.
paraman is offline
Old 12-05-2005, 10:13 AM   #16 (permalink)
Yes mpeg4(Moving Pictures Engineers Group-4) is the lates from them and has better o/p.
Santosh Halemani
- by tkin
