Old 08-05-2005, 09:51 PM   #1 (permalink)
Default BEST PROXY SERVER
hello
pl tell me which is the Best Proxy Server available
sohin is offline
Old 08-05-2005, 09:56 PM   #2 (permalink)
why need title?
bharathbala2003's Avatar
try http://www.findnot.com but then using proxies reduce ur browsing speed drastically..
bharathbala2003 is offline
Old 08-05-2005, 10:24 PM   #3 (permalink)
the speed of your browsing will slow down. However to what extenet is purely dependant on your connection speeds. If your on a 512kbps line and you use a proxy server you wont notice a big difference. however if your on dialup then you will feel the pinch.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 08-05-2005, 10:27 PM   #4 (permalink)
icecoolz which proxy do u suggest ?
sohin is offline
Old 08-05-2005, 10:29 PM   #5 (permalink)
lol...I dont use one...dont need to. Anyways try the anonymisation toolbar. Its simple and will get things done. Else try A4Proxy (google it). I used to use A4Proxy earlier and found it pretty good.
AMD 64 3500+ Venice
icecoolz is offline
- by tkin
