Old 27-07-2008, 11:01 PM   #1 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Angry Resource Hacker Creating Problem........Plz Help!!!!!
Hey frndz..........I tried those "Hack System Properties Dialog Box" and "Transform XP without customization pack" tricks given on VISHAL GUPTA's site www.askvg.com.
But the problem is whenever i save those dll/cpl files after editing with RESOURCE HACKER it gets saved but nothing gets changed, I mean nothing takes effect. A "_original" file gets created...........I deleted that too...........but nothing happens.
I tried this 100 of times but as usual no result..........After editing when I save those files and delete that "_original"...........I reopened that file again..........but surprisingly it's in its original form...........nothing of my edits are there!!!!!!!
I too patched my Windows with "Windows File Protection System" given on that site and Cracked my file protection but nothing happend.............What could be the problem???
Plzzzzzzzz Plzzzzzzzz Plzzzzzzzz Help!!!!!!!!!!!!!!!
Thanks in advance..........
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
Old 27-07-2008, 11:37 PM   #2 (permalink)
New
New's Avatar
Default Re: Resource Hacker Creating Problem........Plz Help!!!!!
If you are using dual OS, just use resource hacker in the first os to hack second's os..
Like using resource hacker in vista to hack xp..This works 2000%
New is offline
Old 27-07-2008, 11:41 PM   #3 (permalink)
Simply a DIGITian
No..........I use only XP
Old 27-07-2008, 11:45 PM   #4 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Dude Copy the file u wanna change to another place
Then make the changes u want & then replace it using replacer
So no probs
BTW : Always keep a backup copy of original files
Take a look at mine
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 27-07-2008, 11:49 PM   #5 (permalink)
Simply a DIGITian
Thanx a lot buddy.............U really helped me a lot............Hey I have 1 more ques.........How can I align those bmp's to left or right??????????
Old 28-07-2008, 01:58 AM   #6 (permalink)
Ecko's Avatar
To Align U have to look at the coordinate locations carefully
Look at this image
To align something equally just make sure you have them equal
Just try out & you'll know how to change
Ecko is offline
Old 28-07-2008, 01:59 PM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Or just select the resource (i.e. image) in dialog box and move it using arrow keys to your desired location. Once you have done, click on "Compile Script" button.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 28-07-2008, 11:25 PM   #8 (permalink)
Simply a DIGITian
Hey vishal.............lotz of thanx...............ur all posts helps me a step forwarding 2 bcome a geek...............thanx again...............
Aftrall I found the problem...............the problem was with "_original" file. I used the "Unlocker" given there 2 ged rid of this prob.............
Last edited by krishnandu.sarkar; 28-07-2008 at 11:26 PM. Reason: Automerged Doublepost
Help, error in using resource hacker Ishani Tutorials 1 22-10-2006 10:00 AM
use of resource hacker prashantban Software Q&A 2 21-10-2006 03:14 PM
Resource Hacker:: qudra Tutorials 1 02-09-2006 09:25 PM
resource hacker vandit QnA (read only) 3 21-08-2005 04:03 PM
Resource Hacker The Incredible QnA (read only) 3 05-06-2005 06:07 PM
- by tkin
