Old 27-07-2008, 10:11 AM   #1 (permalink)
!! RecuZant By Birth !!
naveen_reloaded's Avatar
Default how to create a Partion
I all...
i just now got dell laptop 1530 which came with a 250 gb hard disk..
they have prev have two partition... one for os and another for recovery.. backup ..
after going into disk management in admin tools in cpanel.. i found two other partition .. so it makes a total of 4 ..
now since vista only recognizes 4 partition... how do i add another partition onto it...
Know My Thoughts..
Visit my Blog @ www.Urssiva.com
Visit My Tech Blog @ www.CloudTechnica.com
naveen_reloaded is offline
Old 27-07-2008, 07:44 PM   #2 (permalink)
himtuna's Avatar
Default Re: how to create a Partion
lol
the key
I had used vista earlier and used more than 4 partitions....
Dont know why is it stopping you
Now I dont have space( I download like hell) so
had to move back to XP . It crashed a lot ,64 bit Vista is the safest and stable Ms OS.
http://www.himtuna.com/
http://www.himanshuthakur.com/
Do good to be good !
himtuna is offline
Old 28-07-2008, 08:03 PM   #3 (permalink)
i dont know...
i read somewhere that dell locks or the vista reads only 4 partition ( i doubt this one though )
isthere a way guys ..
i seriuosly need it..
i tried creating a partition with windows disk mamangement... ie Shrink Volume option..
i created a unallocated partition ... but i want able to format or create a volume out of it..
please anyone ?
Know My Thoughts..
Old 28-07-2008, 08:54 PM   #4 (permalink)
Pee into the Wind...
shady_inc's Avatar
My guess is the four partitions you currently have are all primary partitions.FYI, any hard disk can't have more than 4 primary partitions.More partitions can be added be creating a container [called extended partition] and then by creating as many partitions [called logical partitions] as you need inside this container.
Your best bet is to delete one of the current partitions [preferably the very last one] and in that unformatted space, create an extended partition and then create logical partitions inside it.Try something like Gparted for doing this.
Life is as complicated as you say it is.
shady_inc is offline
Old 30-07-2008, 11:33 PM   #5 (permalink)
i cant delete anything as ... 1.OS , 2.Dell~s own recovery partition 3.)Dell Media Direct for use of media center like while switched off laptop 4.)I cant even make out wht it is .. since when i right click on that partition .. i get only "help" on right click.. nothing other...
Gparted ?? how .. please explain....
is there any other way to create a new partition
Know My Thoughts..
Old 30-07-2008, 11:54 PM   #6 (permalink)
peeing on Assembly line
boot into Linux/ or use gparted livecd to better understand your partition structure. then ,limit your extended partition and gain some free space.... and yes ,max 4 primary partitions.that means you have to ..
unban praka123 fsf.org <--- new revolution taking years but succeeding in a regular phase :)
humanbeing is offline
Partion for hard disk 320 gb anni QnA (read only) 1 15-07-2008 09:36 PM
Ubuntu partion merging Kenshin Open Source 13 16-01-2008 12:23 PM
Hard Drive partion ???????? kiranbajpe Hardware Q&A 1 13-06-2007 11:06 PM
partion limit rounit Software Q&A 1 15-10-2006 09:16 AM
Need a partion manager logins QnA (read only) 7 15-04-2006 10:44 PM
- by tkin
