Old 08-05-2005, 05:53 PM   #1 (permalink)
Default pls suggest ne gud cabinet
hi guys. i can't decide which cabinet should i buy. antec or somethin else. antec is getting expensive for me. the max i wanna spend on a cabinet is 4k.how r intex and iball cabinets. ohh yes i wanna buy a 400w cabinet. could someone also give the number of the trusted dealer in delhi.
supersaiyan is offline
Old 08-05-2005, 07:46 PM   #2 (permalink)
The Hardware Labs
mohit's Avatar
go for VIP cabinets and power supplies from Kunhar peripherals. You will easily get them under 4k and they have decent quality.
You can also try Zebronics for cabinets and power supplies. Thei geforce cases are good and you can buy a separate power supply for around 3k. Total cost for zebronics is around 5k.
visit www.zebronics.com and check the models and you can also post online enquiries on their site.
mohit is offline
Old 08-05-2005, 09:29 PM   #3 (permalink)
Is 4K ur Budget for Cabby + PSU.
If its only for Cabby then look at none than
Antec SLK 3700BQE[Black] or SLK3700[Beige]
Best cabbies with 350W Smart Power PSU go for thes cabbies without PSU.
Info:- www.antecindia.com
And get a 400W PSU which ever u want.
Do let me know ur sys config so i can suggest u a better PSU.
Overclock Me.
Overvolt Me.
AMD Me.
quad master is offline
Old 11-05-2005, 09:58 AM   #4 (permalink)
TE God
Hey guys is this XCLIO cabinet from Zebronics worth it ?
The guy sells it retails for 3k w/o SMPS.
Pics and specs are here.
The guy says its an one-of-its-kind case with some really cool features. Check it out and let me know whether I should go for the Super Lanboy or this.
anishcool is offline
Old 11-05-2005, 11:03 AM   #5 (permalink)
iBox Grabit+Antec/VIP power supply = satisfied you
SatishSays.com
twitter.com/satishsays
devilhead_satish is offline
Old 11-05-2005, 01:35 PM   #6 (permalink)
rohanbee's Avatar
ibox has some definately good looking cabinets and reasonably priced. like my friend above pointed out the ibox grabit is quite nice........
Quote by Garfield'
rohanbee is offline
Old 11-05-2005, 01:39 PM   #7 (permalink)
geek_rohit's Avatar
Be careful with iBox SMPS. It sucks.
SportZForumZ - We Know Your Game Better
http://www.sportzforumz.com
My Site & Blog
http://www.rohit-sharma.com
geek_rohit is offline
Old 11-05-2005, 01:52 PM   #8 (permalink)
dude in india decent psu are of antec and starnet
for psu
go for 400watts antec for 2700approx+tax+transport if not in chennia if there
3450 for 450watts+all that tax etc
cabinet look at zebronics,iball etc
which is good cabinet for 1.5-2k
akshayt is offline
Old 11-05-2005, 01:55 PM   #9 (permalink)
club_pranay's Avatar
i suggest u go for Mercury SMPS and cabinet. quality fine but after sales service is excellent!!
i think all the branded ones are good.... but unbranded(cheap) ones are poison for your system!!
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 12-05-2005, 03:04 PM   #10 (permalink)
mumbai prices for antec...
slk cabinet with 350 watts smart power supply ...3800 for white and 4200 for black...
lanboy cabinet without power supply...5500.....
antec 350 watts smart power....2200...
480 watts true power....5500/-
550 watts true power with eatx connectors....6500/-
if not using pci-e gfx...best is to take smart power....otherwise take true power...
Ankit is offline
Old 12-05-2005, 11:55 PM   #11 (permalink)
even boxes from zebronics and newtec can be concidere.
**** happens
pradeep_chauhan is offline
Old 13-05-2005, 12:52 AM   #12 (permalink)
well i will be usin a gainward 6600gt pci-ex. should 350w be enough?
Old 13-05-2005, 09:55 AM   #13 (permalink)
no for pci e go for atleast 400w and if possible more than that
Happy Computing :lol:
krishnathelord is offline
Old 13-05-2005, 11:04 AM   #14 (permalink)
Default ps
no 350 W....400 W at least if using true power...otherwise go for 450 W and up....go for a 24 pin connector eatx power supply...but most of the power supplies..though having 24 pins...dont provide separate rails for the extra 4 pins...hence better to go for true power...and if u can afford and get it go for true550eps...this is 550w eatx supply...presently the only antec model having 24 pin connector...
Ankit is offline
Old 13-05-2005, 11:17 AM   #15 (permalink)
abhi_shake's Avatar
The Frontech Saturn ATX is ultra cool. It's got blue LED's on the side and it looks amazing when u switch off the lights!!!!!!!!!!!! It has got adequate drive bays ( 4 for hard drive, and four cd roms), but it's got a 350Watt power supply. It also does not cost too much about Rs 2000.
'Its God's responsibility to forgive the terrorists organisations like Jaish-e-Mohammed, Lashkar-e-tayeba etc. Its our responsibility to arrange the meeting between them' - INDIAN ARMED FORCES
abhi_shake is offline
Old 13-05-2005, 11:55 AM   #16 (permalink)
i hav heard zebronics 500w smps cost ard 1300..is it a good buy...also if the power used by the system is less than the watts rasting does it harm the comp?????
magnet is offline
- by tkin
