Old 27-07-2008, 08:14 AM   #1 (permalink)
Seed is the Life!!
shift's Avatar
Default Partitioning :: what if i delete???
searched a lot, but couldn't find a thread about this prob
so i created a new one....
heres the prob,
most laptop that has pre-installed Windows Vista used to come to 2 partition, C and D
in HP laptop, D drive is mainly for HP RECOVERY
ok, what if i delete (or format) all in the D drive??
because i want to create 2, 3 partition
and nothing can be stored on that (HP RECOVERY) drive
thanks again...........
Stupidity Causes Cancer !!
shift is offline
Old 28-07-2008, 10:50 AM   #2 (permalink)
Default Re: Partitioning :: what if i delete???
If you format the Recovery partition, you'll lose the ability to restore everything that came installed in the computer, including the OS. It's as simple as that. However, you could back up before you do it.
pimpom is offline
Old 28-07-2008, 10:49 PM   #3 (permalink)
TooR
alok4best's Avatar
^^^ exactly...
I wish !!
alok4best is offline
Old 28-07-2008, 11:04 PM   #4 (permalink)
TheSaint
NucleusKore's Avatar
Just see in the start menu if there is an option to create recovery cd/dvd. Once that is done ask your hp service centre and then delete it.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Partitioning HDD?? shwetanshu Reviews 6 22-11-2008 02:41 AM
Partitioning Questions ring_wraith QnA (read only) 2 22-05-2008 01:42 PM
New HDD and partitioning Shikhar QnA (read only) 6 27-04-2008 01:13 PM
Partitioning hd....??? Pragadheesh QnA (read only) 4 14-02-2007 05:00 PM
Partitioning .......... Mr.Cool QnA (read only) 10 07-07-2006 12:57 AM
- by tkin
