Old 27-07-2008, 01:28 AM   #1 (permalink)
raksrules's Avatar
Default Minimum requirement for KGB Archiver to work ?
I have a Pentium 4, 2.4GHz machine. I have a 160 KB kgb archive which claims to have 700 MB Movie file. I tried to decompress it but it said "Not enough memory". What is the Minimum requirement for KGB Archiver to work ?
Out of curiosity, can KGB archiver compress things to such a small size ??
raksrules is offline
Old 27-07-2008, 07:41 AM   #2 (permalink)
Default Re: Minimum requirement for KGB Archiver to work ?
Yes it can compress to very small sizes provided you are having the resources. It works with even 128 MB of memory, but if you want to compress to maximum possible value, even 2GB ram is not enough.
ThinkFree is offline
Old 27-07-2008, 02:04 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
First of all
its time consuming and u are NOT at all sure that after wasting 4-5 hrs of compressing a s/ware into KBs adn then uncompressing it for 8-9 hrs, the file is corrupted...its really annoying...
and this has been a pain for various users...who hv used it...
btw, its a system hog to tell u the least..and yes even 2 GB ram is not enough..as EXTRA RAM will not help u to reduce the compresion or decompression timings...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 27-07-2008, 02:14 PM   #4 (permalink)
Google Bot
Pathik's Avatar
You need atleast 2 GB RAM and a good proccy for decent KGB decompression. And even then It ll take insane amounts of time.
Pathik is offline
Old 27-07-2008, 02:16 PM   #5 (permalink)
dOm1naTOr's Avatar
it seems ur root partition is out of free space. While compressing, it needs lots of storage as temp, and its not the ram which is insufficient.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 29-07-2008, 02:19 PM   #6 (permalink)
raksrules's Avatar
Can anyone suggest me some websites / links where i can find stuff in KGB format ?
what is the minimum requirement for NFS PROSTREET heartripple Gamerz 9 12-05-2008 10:02 AM
What is the minimum requirement for a External TV Tuner Card? sakthirajesh Hardware Q&A 8 02-11-2007 08:13 PM
Linux@minimum requirement sharma_atul85 Open Source 23 03-09-2007 10:14 PM
Minimum requirement for vista gau_pppu Hardware Q&A 11 07-01-2007 09:58 PM
Minimum hardware requirement to install Pinnacle Studio... Tapomay QnA (read only) 6 26-11-2005 12:02 AM
- by tkin
