Originally Posted by anurag_online
Yes you can easily change it to FAT32. DO the following...
Log on to windows XP.
Then remove all the data from that drive.
Now format it completly by right clcicking on the drive and select the partition style as FAT32. You r done!!!
Thanx for the replies. Is formatting the only choice i have? Anyways i wll try it .
Antec Cabinet, P4 2.8 ghz (HT), Sony Dvd Rom, XFX 5600 U, MSi 875 Neo2, 80 GB Seagate Barracuda 7200 RPM, Creative SB live 5.1, Creative Inspire 4.1 4400, Corsair 512 MB DDR
