I am facing a problem from last two months.In my windows i always use to get a blue screen error : "IRQ_NOT_LESS_OR_EQUAL".
I have cleaned us my PC hardware and even installedmy os multiple times but it didn't helped can you tell me the reason why does this happen or any alternative to get rid of it.
IRQ sharing conflict.
Enter ur bios n disable all hardware n ports u wont be using.
Eg. Serial, midi,parallel,usb controller n other unnessary onboard divices.
This will free up a lot of irq s.
Then Install windows.
Go for a fresh install rather than an upgrade if possible.
If reinstalling.
Start RegCleaner.
Use the optoin of 'Reset entire hardware configuration'
After this all devices will be uninstalled.
N after reboot u will be asked to provide the driver disks.
Rather skip this step ie. let the default generic drivers install.
Run windows setup n upgrade the drivers later.
Most probably i m askin u to do many unnessary steps which r not needed.The actual solution would be a lot simpler.
Watch this thread n the guys will help u out of this simple problem.
Ie. If some of ur hardware is not faulty.
Hmmm.. That happens due to Driver conflict .. What is the exact error message ..? It will help in determining the course of action ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
