Hi Mario,
man as the old saying goes, search for the thing where you lost it. There are 3 ways to do resolve.
1) Install tweak XP again and search for the option to enable Windows hotkeys.
(Very bad way)
2) From Registry:
User Key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer\
System Key
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Policies\Explorer\
Change the value for "NoWinKeys" to 0
(0= disable restriction, 1 = enable restriction)
and plz backup registry b4 making any changes to it.
3) Most safer way to do it. Download TweakUI from:
http://www.microsoft.com/windowsxp/d...powertoys.mspx
Under Explorer category, check "Enable Windows+X hotkeys". thats it, done.
Post reply after try. awaiting ur reply.
